[Qgis-user] [processing]: input selection type in modeler ?
Andreas Plesch
andreasplesch at netscape.net
Mon Apr 3 11:04:32 PDT 2017
Processing python scripts can have a variety of parameter types including
selection:
http://docs.qgis.org/2.18/en/docs/user_manual/processing/scripts.html
- selection. A dropdown menu that allows the user to select from a
pre-populated list. For example units=selection sq_km;sq_miles;sq_degrees
If I want to use a script algorithm with such a selection input type in the
modeler, there does not seem to be a way to use a corresponding selection
input in the modeler (instead it is necessary to provide a fixed choice of
the available selections as a string).
Am I overlooking something ?
Thanks, Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170403/32cc6d00/attachment.html>
