[Qgis-user] degrees: is degr/min/sec still used? Or decimal preferable?
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Mon Apr 10 02:57:04 PDT 2017
I don't think the problems with accuracy stem from the limited number of
decimals in a /double/ variable
  * The circumference of earth: ca. 40.076 km.
  * 1 degree in meters 40076 km / 360 = 111.32 km/degree = 111320 m/degree.
  * A double has 52 bits precision, roughly 15 digits (in 10 exponent).
    That means that the decimal degree has a precision of around
    111320/1000000000000000  = 1.1132e-10 m = (ca.) 1e-7 mm.
    (That should be enough for everyone...)
  * However, if you store your decimal degree value as a single
    precision real with 23 bits precision (aka. 7 digits precision in 10
    exponent), it's another story:
    This will give you around: 111320/10000000 m = 0.011132 m = 11.132 mm
So store your decimal degree as doubles, not single precision real.
Regards
Bo Victor Thomsen
Municipality of Frederikssund, Denmark
Den 10/04/17 kl. 08:39 skrev Richard Duivenvoorde:
> Hi List,
> Had a discussion here with some people about the use of showing the
> latlon degrees in degrees/minute/seconds tuple instead of the decimal
> notation:
> "4.40069397,51.71060887"
> vs
> "4°24′02.49807059″E,51°42′38.19184916″N" (or variations on that)
> Is there some general preference in this? To me the first one is just
> easier to handle, but I'm not sure what the general preference is in the
> GIS world.
> Any comments?
> Or is everybody using the national crs's anyway :-)
> Regards,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170410/e07391ae/attachment.html>
