[Qgis-user] Detecting node valences
Martin Bain Martin.Bain at lismore.nsw.gov.au
Wed Apr 12 19:44:37 PDT 2017
Hi Pat,
I saw your previous question went unanswered.  I’m not familiar with the term valence, I’m guessing you want the number of lines that meet at a point.  If you had like a roads layer then three streets would meet at a T intersection – the node would have a valence of three, for a cross intersection the valence would be four.
I’ll start the ball rolling by offering a possible solution, then maybe some bigger brained folks might give a better way of doing it.
There’s probably a sequence of steps you could do to get your end result, maybe something in the processing toolbox?  Being a bit of a database guy, I reached for the DB Manager and came up with the SQL below which can be loaded as a point layer.  THIS QUERY ASSUMES YOUR LINES ONLY MEET AT THE ENDS, IF ONE LINE INTERSECTS ANOTHER IN THE MIDDLE IT WONT BE COUNTED.
The inner select statement returns a set of points. It is a UNION query of two parts, the first part selects each line’s start point and its X and Y coordinates and the second part does the same for the end point of each line.
The outer select statement groups the matching points together and gives a count.  The last line in the query “HAVING VALENCE>2”  filters out any results with a valence less than three, you can adjust the number for your needs or leave it out altogether and filter the rows in QGIS.
Cheers,
Martin.
SELECT GEOMX,GEOMY, GEOM, COUNT(*) AS VALENCE
FROM
SELECT "LCC_WATER_PIPES"."Namecompon",
"LCC_WATER_PIPES"."MI_PRINX",start_point(
"LCC_WATER_PIPES"."geometry") AS GEOM ,
X(start_point("LCC_WATER_PIPES"."geometry")) AS GEOMX,
Y(start_point("LCC_WATER_PIPES"."geometry")) AS GEOMY
FROM "LCC_WATER_PIPES"
UNION
"LCC_WATER_PIPES"."MI_PRINX",end_point(
X(end_point("LCC_WATER_PIPES"."geometry")) AS GEOMX,
Y(end_point("LCC_WATER_PIPES"."geometry")) AS GEOMY
GROUP BY GEOMX, GEOMY, GEOM
HAVING VALENCE>2
select A.MI_PRINX,B.MI_PRINX ,intersectION(A.geometry,B.geometry) AS GEOM
from LCC_WATER_PIPES as A, LCC_WATER_PIPES as B
WHERE A.MI_PRINX<>B.MI_PRINX
AND intersects(A.geometry,B.geometry)=1
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of phi73 at gmx.de
Sent: Wednesday, 12 April 2017 11:03 PM
To: QGIS User List <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Detecting node valences
Hello to all,
is there a way i QGIS to run a select over a map to get
all the nodes with a specific node valence?
If not i would be happy about a shortchanged reply too :)
thanks
pat
This email is intended for the named recipient only.  The information it contains may be confidential.  If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it.  If you have received this email in error, please contact the sender immediately and delete the message.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170413/e4c1f7d4/attachment.html>
