[Qgis-user] LRS (Linear Referencing System Plugin)
Werner Macho werner.macho at gmail.com
Tue Apr 18 05:12:37 PDT 2017
Hi!
Just out of curiosity - would the qchainage plugin be enough for you?
regards
Werner
On Tue, Apr 18, 2017 at 2:10 PM, Tyler Veinot <tylerkveinot at gmail.com> wrote:
> Hello;
> Has anyone used the Linear Reference System Plugin in QGIS aka LRS Plugin?
> I would like to display events as points and lines based on measured
> distances along a linear feature. I can get lines working with an event
> table with; Route_ID, Measure_From, Measure_To fields but I cannot seem to
> display point events. I tried Route_ID and Measure fields and Route_ID with
> the Measure_To and Measure_From valves as the same number but no go.
> Anyone using LRS to display point events?
> Tyler
> Qgis-user mailing list
