[Qgis-user] core dumped when opening project (QGIS Master)
Gustavo Martínez
gmpuljak at yahoo.com.ar
Fri Apr 28 11:03:13 PDT 2017
I've compiled QGIS Master (rev. 5a19463) and when I try to open a
project I use on QGIS 2.14, I get the following error:
Warning: QObject::connect: signal not found in QgisAppInterface
ERROR 4: /initrd.img: Permiso denegado
ERROR 1: Max token size reached
Warning: Loading a file that was saved with an older version of qgis
(saved in 2.14.5-Essen, loaded in 2.99.0-Master). Problems may occur.
Warning: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3472,
resource id: 34778991, major code: 40 (TranslateCoords), minor code: 0
Warning: QPainter::begin: Paint device returned engine == 0, type: 3
Warning: QPainter::setRenderHint: Painter must be active to set
rendering hints
Warning: QPainter::setBrush: Painter not active
Warning: QPainter::setPen: Painter not active
Warning: QPainter::translate: Painter not active
Warning: QPainter::drawPath: Painter not active
Warning: QPainter::end: Painter not active, aborted
Warning: QPainter::begin: A paint device can only be painted by one
painter at a time.
QGIS died on signal 11Warning: QPainter::setRenderHint: Painter must be
active to set rendering hints
painter at a time.
rendering hints
painter at a time.
rendering hints
painter at a time.
rendering hints
painter at a time.
rendering hints
painter at a time.
rendering hints
Could not attach to process. If your uid matches the uid of the target
process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or
try
again as the root user. For more details, see /etc/sysctl.d/10-
ptrace.conf
ptrace: Operación no permitida.
No se seleccionó hilo
No stack.
gdb returned 0
Aborted (core dumped)
How can I fix it?
Thanks.
Gustavo Martínez <gmpuljak at yahoo.com.ar>
