[Qgis-user] plugin error messages on startup
Chuck Yahrling ab1vlqso at gmail.com
Wed Aug 16 04:59:48 PDT 2017
continuing the above post......
I'm noticing that the Query console often gives me bad Python syntax errors
when using standard Boolean query buttons as I follow published v 2.18
tutorials step-by-step. That may be unrelated but I'm too much of a noob to
know if that is coincidental or not.
On Wed, Aug 16, 2017 at 7:49 AM, Chuck Yahrling <ab1vlqso at gmail.com> wrote:
> QGIS 2.18.11 installed from windows 64 bit installer. running windows7 w
> /latest updates:
> 2017-08-16T07:11:31 1 Failed to load C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/globeplugin.dll
> (Reason: Cannot load library C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/globeplugin.dll:
> The specified module could not be found.)
> 2017-08-16T07:11:31 1 Failed to load C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/grassplugin7.dll
> (Reason: Cannot load library C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/grassplugin7.dll:
> qgis/plugins/grassprovider7.dll (Reason: Cannot load library
> C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/grassprovider7.dll: The
> qgis/plugins/grassrasterprovider7.dll (Reason: Cannot load library
> C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/grassrasterprovider7.dll: The
> The above messages show in the messages console on startup everytime I
> launch QGIS Desktop 2.18.11.
> I verified that the dlls mentioned are in the directories ( assuming the
> ~1 is some type of python variable that resolves to yield a standard
> directory name) so I don't understand why they are not being loaded. Are
> the messages telling me that the dlls can't be found or that some libraries
> the dlls need cannot be found?
> I still see this when I load QGIS desktop with grass support.
> Extensive googling has yielded only unresolved guess threads on previous
> versions.
> Is this even an issue?
> I'm noticing that the Query console keeps ercing out with bad Python
> syntax when I follow pibliched tutorials
> 73, chuck
> ab1vl.com
73, chuck
ab1vl.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170816/95abdce4/attachment.html>
