[Qgis-user] Updating a field set with default global variable on edit
Casper Bertelsen casperbj94 at gmail.com
Tue Aug 22 06:45:17 PDT 2017
Hi Ross,
If you make your project without saving username and password, the
project will prompt for a user and password when opened. Then each
member can login using their assigned login and thus making it possible
to use current_user in postgres.
To remove saved username and password from your current project file
(make a copy, beforehand), you can open it in a text editor and seach
for <layername> untill you find
<datasource>dbname='xx' host=yy port=5432 four lines above
<layername>and remove the username and password-part only .
Mvh. / Best regards
Casper Bertelsen
On 22/08/2017 15:36, McDonaldR wrote:
> Thanks Karl-Magnus
> We use triggers in the database already and they work perfectly but if
> we want to record the specific user creating and editing features then
> we’d have to create separate projects for each user.  At the moment
> the team of about 10 users all use a set of centrally stored project
> files – one for each different task.
> I found this post on Stackexchange
> (https://gis.stackexchange.com/questions/217011/how-to-automatically-update-wfs-edits-with-a-user-id)
> where global variables are used to populate fields when features are
> added.  However, as Matthias notes in the comments this doesn’t work
> on feature  “update”.  If this were possible then it would meet all
> our needs.  Maybe something that could be funded?
> Ross
> *From:*Karl Magnus Jönsson [mailto:Karl-Magnus.Jonsson at kristianstad.se]
> *Sent:* 22 August 2017 12:34
> *To:* McDonaldR; qgis-user at lists.osgeo.org
> *Subject:* SV: [Qgis-user] Updating a field set with default global
> variable on edit
> Hi!
> I’ve made the same things with triggers in the database. To avoid
> getting same username I’ve chosen not to save the username and
> password in the project. But then the user have to enter it every time
> the projects opens. If you can find a solution to your suggested
> approach it would be nice.
> *Karl-Magnus *
> *Från:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *För
> *McDonaldR
> *Skickat:* den 22 augusti 2017 13:12
> *Till:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> *Ämne:* [Qgis-user] Updating a field set with default global variable
> on edit
> Hi List,
> Anyone know how to update a field that has a global variable set as
> the default value when records are edited (geometry and/or attributes)?
> We have a QGIS project with a PostGIS layer loaded and configured with
> look-ups and relations so the users can update all the relevant
> fields. There are also "*created_by*" and "*updated_by*" fields. These
> are updated by a trigger in the database with the "*current_user*"
> database variable. This works fine if you are the current user that
> added the layer to the project - the trigger works perfectly.
> If you give the project to someone else and they create and edit
> features in the layer the fields are still updated with your name as
> you are the person who added the layer to the project. Not what we want.
> QGIS has global variables and there are some new ones -
> *user_account_name* and *user_full_name* that can be set as default
> values for the fields. When a new feature is created the field is
> populated with the correct name. Which is what we want.
> However, when we update an existing record we'd like the
> "*updated_by*" field to be updated with the current
> "*user_account_name*". Like a trigger in the database would do on
> update. Then we would have a better idea of the history of the feature.
> Ross
> *Ross McDonald | *GIS Data Coordinator | Angus Council, People, IT |
> Angus House, Orchardbank Business Park, Sylvie Way, Forfar DD8 1AT*|
> t: 01307 476419*
> This message is strictly confidential. If you have received this in
> error, please inform the sender and remove it from your system. If
> received in error you may not copy, print, forward or use it or any
> attachment in any way. This message is not capable of creating a legal
> contract or a binding representation and does not represent the views
> of Angus Council. Emails may be monitored for security and network
> management reasons. Messages containing inappropriate content may be
> intercepted. Angus Council does not accept any liability for any harm
> that may be caused to the recipient system or data on it by this
> message or any attachment.
> management reasons.Messages containing inappropriate content may be
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170822/ec41a188/attachment.html>
