[Qgis-user] Presets in Layers Panel
Lene Fischer lfi at ign.ku.dk
Sat Dec 30 00:54:08 PST 2017
Hi Nyall,
You can change the setting for a layer eg. Color and then make a preset.
So if I have a layer and I want to present it in 3 different colors/classifications
How would you then suggest I make 3 different presentations ?
Kind regards
Lene
Lene Fischer
-----Original Message-----
From: Nyall Dawson [mailto:nyall.dawson at gmail.com]
Sent: 29. december 2017 23:46
To: Lene Fischer
Cc: qgis-user
Subject: Re: [Qgis-user] Presets in Layers Panel
On 30 December 2017 at 08:07, Lene Fischer <lfi at ign.ku.dk> wrote:
> Hi,
> I´m trying to use the ‘Preset’ function in the Layers Panel.
> But I can only add one preset and then ‘Add Preset’ is greyed out.
> It might be me who use it wrong, but could I get someone to try it out before I file a ticket.
Yep, you're using it wrong! :)
Think of creating presets like a "snapshot" of the current configuration. The action is disabled if the current state already matches an existing preset. So you need to make some change to the configuration (e.g. toggling some layers), and then you'll be allowed to create another preset.
Nyall
