[Qgis-user] Selecting Objects from an ESRI file based geodatabase
armin.konrad at email.de armin.konrad at email.de
Wed Feb 1 06:37:39 PST 2017
Thank you for your answers! It worked as you suggested. I filtered the
gdb database to the objects that I needed and saved them as shape.file.
Afterwards I could delete the database in the project and work with the
shape file instead with reasonable speed.
Thanks again
Armin
Am 01.02.2017 um 14:30 schrieb Lester Anderson:
> The only way I am aware of, is to load the .gdb file, select the
> layer(s) you want and then use the save-as option to save out as a
> shapefile.
> On 1 February 2017 at 12:22, Tyler Veinot <tylerkveinot at gmail.com> wrote:
>> You can right click a layer and go to filter and enter an expression to
>> filter out unwanted objects. From there save as will save to a shapefile,
>> among other other formats, that will only be the items defined by the
>> filter. You can also use a select expression and in the save as dialog
>> select save only selected features
>> Does that help?.
>> On Wed, Feb 1, 2017 at 8:12 AM, Armin Konrad <armin.konrad at email.de> wrote:
>>> Hi,
>>> I have opend an ESRI .gdb database (directory) in an qgis project. The
>>> mayor .gdbtable-file has a size of about 3.5 GB and contains about 18.000
>>> objects (polygons). It is rather awkward to work with such a database to say
>>> the least since I need only 2 to 3 objects at a time.
>>> I wonder, is there a way to select certain objects by filtering and
>>> convert them selectively to a shape file or to copy them to a new database?
>>> Thanks you for suggestions.
>>> Armin
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
