[Qgis-user] WMS problems in Qgis 2.18.3 - legend causing trouble
magerlin
MAP at ramboll.dk
Sat Feb 4 03:43:41 PST 2017
I have a very simple (test) Qgis project which just shows a WMS layer (from
EU but same problem with other WMS): WMS_Problems.qgs
<http://osgeo-org.1560.x6.nabble.com/file/n5306308/WMS_Problems.qgs>
It work flawless in Qgis 2.18.1 and displays a nice legend in the Layers
Panel.
But opening it in Qgis 2.18.3 causes strange behavior:
* When you move the mouse the legend is sometimes visible in the layers
panel and sometimes the layers panel is completely wiped out including other
layers which should have been shown there.
* When layers panel is wiped out Qgis often makes the whole PC hang and
nothing left than ctrl+alt+del to kill Qgis.
Problem occurs in Win 7 64bit.
Anybody else can confirm this behavior?
Regards Morten
Currently using Qgis 2.18.3 (OSGeo4),
Windows 7, 64bit
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-problems-in-Qgis-2-18-3-legend-causing-trouble-tp5306308.html
Sent from the QGIS - User mailing list archive at Nabble.com.
