[Qgis-user] Data Defined operation
Springfield Harrison stellargps at gmail.com
Tue Feb 7 21:11:40 PST 2017
Thanks Nyall & Don,
     Obvious when explained!  Excellent, lots of power here.
             Thanks again . . . .
Cheers . . . . . Spring
On 07-Feb-2017 20:31, Nyall Dawson wrote:
> On 8 February 2017 at 14:08, Springfield Harrison <stellargps at gmail.com> wrote:
>> Hello,
>>      Attempting to use the Data Defined function (tool?).
>>      The following configuration has no effect; it may be looking for a
>> colour input.  This DD is to set the background colour on a label where Type
>> = SL.
>>      If I use this function on bold Text, it works but that requires no
>> input, it just toggles.
>>      Where am I supposed to enter the "Expected Input" colour specifications?
> The expression needs to evaluate to a color string, whereas your
> expression evaluates to a boolean value.
> Something like this is acceptable:
> case when "Type" = 'SL' then '#ff0000' else '#00ff00' end
> Nyall
>> Data defined override
>> Active: yes  (ctrl|right-click toggles)
>> Expected input:
>> string [r,g,b,a] as int 0-255
>> Valid input types:
>> string
>> Current definition (expression):
>> "Type" = 'SL'
>> Thanks very much . . . .
>> Cheers . . . . . Springfield Harrison
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
