[Qgis-user] Join hangs in Las Palmas
Holly Wilkie
bells.holly at gmail.com
Wed Feb 8 08:14:39 PST 2017
Thanks Andreas, that makes a lot of sense.
On Wed, Feb 8, 2017 at 2:42 AM, Andreas Wicht <a.wicht at gmail.com> wrote:
> I recently encountered that issue as well and I observed the behavior
> only when the attribute table was opened.
> For me it works just fine when I close the attribute table (no matter
> if docked or undocked) before I do the join.
> Maybe try that for a start.
> Still, I think that problem should be investigated in more detail.
> > From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of
> > Bernd Vogelgesang
> > Sent: Dienstag, 7. Februar 2017 13:52
> > To: qgis-user at lists.osgeo.org
> > Subject: Re: [Qgis-user] Join hangs in Las Palmas
> > Hi,
> > did you already try to create a new joined layer with the processing
> toolbox
> > instead of creating a "loose" join with Properties/Joins?
> > I almost never do joins through the properties but instead create
> permanent
> > joins with "Join attributes table" from the toolbox.
> > It could be possible that your machine has not enough power/memory when
> > non-permanently joining huge data sets.
> > Good luck
> > Bernd
> >> Am 06.02.2017, 21:16 Uhr, schrieb Holly Wilkie <bells.holly at gmail.com>:
> >> Hi, I've noticed that when I try to do a Join, the software hangs and I
> have
> >> to close the App. Usually, the join works after I restart. However, I am
> >> currently trying to join a table of parcel ownership data provided by a
> >> Texas county with a shapefile provided by the same county. The data
> type for
> >> the columns is the same. They are both rather large files. When I set
> up the
> >> join, QGIS hangs and I am unable to get the join to work upon
> restarting.
> >> Has anyone else noticed this issue?
> > Bernd Vogelgesang
> > Siedlerstraße 2
> > 91083 Baiersdorf/Igelsdorf
> > Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170208/20d2a5f1/attachment.html>
