[Qgis-user] How to 'difference' in existing layer
Lene Fischer
lfi at ign.ku.dk
Mon Feb 13 15:16:39 PST 2017
Hi Jorge,
Clip will, as you write result in a new file. I would like to perform the action on the first file - as if I manually use 'Add ring' in the Advanced Digitizing toolbar.
Regards
Lene
-----Oprindelig meddelelse-----
Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Jorge Gustavo Rocha
Sendt: 13. februar 2017 23:53
Til: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] How to 'difference' in existing layer
Hi Lene,
I'm not sure if I understood the question.
I would try the clip operation. You use the second layer to cut the first layer. But the result is another layer. But a layer with holes :-)
I hope it helps!
J. Gustavo
Às 22:41 de 13-02-2017, Lene Fischer escreveu:
> Hi
> I have two layers of polygons
> I want to make holes in the first layer using the second layer as mask.
> I can do this by function ‘Difference’ – but the result is a third layer.
> I would like the holes in the polygons to be in the first (existing) layer.
> Any suggestions J
> Regards
> *Lene Fischer***
> Associate Professor
> *University of Copenhagen***
> Department of Geoscience and Natural Resource Management
> Forest and Landscape College
> Nødebovej 77a
> 3480 Fredensborg
> Denmark
> DIR +45 35331579
> MOB +45 40115084
> lfi at ign.ku.dk <mailto:lfi at ign.ku.dk>
> www.ign.ku.dk <http://www.ign.ku.dk/>
> cid:image001.gif at 01D2444C.0C2DB110
> Qgis-user mailing list
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
