[Qgis-user] Fwd: Import and convert points from Google Maps
Renato Saboya
rtsaboya at gmail.com
Mon Feb 20 05:26:13 PST 2017
Dear all:
I am trying to generate a point shapefile from lat/long coordinates
obtained from Google Maps' API. They were generated by a WordPress plugin
(Gravity Forms Geolocation Add-on) and processed in R to generate a new CSV
file with the latitude and longitude in Y and X columns, respectively. I
tried to import them to QGIS using "Add delimited text layer..." and EPSG
3857, which I found online to be the EPSG of Google Maps. I now want to
convert this layer / shape to UTM in order to integrate it with my other
layers.
The points are created correctly, apparently. When I check their
coordinates and compare to the ranges of values in Google Maps, they seem
ok.
[image: Inline images 1]
However, if I try to load another shapefile of the same location, it falls
very far from the points. Similarly, If I try to load a map from
QuickMapServices, it doesn't work: "*QuickMapServices: Failed to download
all 1 files. - Google Satellite*".
When I save the point shape to UTM (EPSG 31982) to check the coordinates,
the values are not coherent with other shapes of the same location:
Converted coordinates:
[image: Inline images 4]
What the coordinates should look like (approximate values):
[image: Inline images 5]
I also tried inverting the values of lat / long to x and y, to no avail.
Any thoughts would be highly appreciated!
Thanks in advance.
Regards,
*Renato T. de Saboya*
Universidade Federal de Santa Catarina
Programa de Pós-Graduação em Arquitetura e Urbanismo (PósArq)
Urbanidades <http://urbanidades.arq.br> | Infoarq
<http://infoarq.arq.ufsc.br/> | PósArq
<http://posarq.ufsc.br/renato-t-de-saboya/> | Academia.edu
<http://ufsc.academia.edu/RenatoSaboya> | ResearchGate
<http://www.researchgate.net/profile/Renato_Saboya>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170220/adfb697f/attachment.html>
Name: Screenshot - 18_02_2017 , 10_43_35.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170220/adfb697f/attachment.png>
Name: Screenshot - 20_02_2017 , 10_19_30.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170220/adfb697f/attachment-0001.png>
Name: Screenshot - 18_02_2017 , 10_44_27.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170220/adfb697f/attachment-0002.png>
