[Qgis-user] Forced raster export
Stephen Wandling swandling at gmail.com
Tue Feb 21 08:11:15 PST 2017
Hi Richard,
Yes, I can see my question was not very clear.  I do not want a raster
PDF.  Composer has automatically set that option to Print as Raster
because of "Advanced composition effects" (from the error message), and
mentions "blended modes" or "vector layer transparency" being enabled.
I found and removed a transparency set on one component, but that did
not change the situation.  I may have 'blended modes' set, but I do not
know what they are, so I can not look for them.  And, the problem may be
some other 'advanced composition effect'?
So, my question is: What must I do to get my map to not export as a Raster?
Thanks for your response,
Stephen
On 21/02/2017 3:34 AM, Richard McDonnell wrote:
> Hi Stephen,
> Not exactly sure, but It may be that you need to have the *Print as
> Raster* option Picked.
> Its in *Export Settings* under *Composition*.
> Hope it helps,
> Regards,
> Richard.
> On 20/02/2017 21:38, Stephen Wandling wrote:
>> I have pulled together data from a few sources for my current map
>> project.  I was getting coordinate issues until I noted the "Set
>> Projet CRS from Layer" option.  So, I have been adding a shape file
>> from the local Regional District and setting the CRS to that.  Then I
>> add other layers.  It seemed to be dealing with my coordinate issues.
>> But now, when I create my map in Composer, when I go to Save, as a
>> PDF, I am informed that I have to save as a raster.  The notice
>> mentions 'blended modes' and 'vector layer transparency'.  I did have
>> a transparency set for one layer, which I eliminated, and I do not
>> know what 'blended modes' might mean, unless it means the 'blended
>> CRS' I have created in my map?
>> The raster PDF does not meet my needs.
>> Stephen
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
