[Qgis-user] QGIS to manage cadastre
Neumann, Andreas
a.neumann at carto.net
Sun Jan 8 23:19:07 PST 2017
Hi Nyall,
There is a little bit of overlap of people involved, but it is mostly
different people. But they will build upon the experience made in the
qWat/QGEP projects. And I hope they can also contribute back to the core
project.
One technique they will try to use is the new QGIS project generator
that Matthias is currently developing - a tool that can generate a QGIS
project based on a configuration with YAML files and a data model out of
a PostgreSQL database. Still early days for this development - but
hopefully it will be a success. The idea is to save parts of the tedious
work, such as setting up relations, constraints, etc. Stuff that is
already defined in the database / data model. Probably a topic to
discuss at the next dev meeting.
Greetings,
Andreas
On 2017-01-09 01:21, Nyall Dawson wrote:
> On 6 January 2017 at 06:31, Andreas Neumann <a.neumann at carto.net> wrote:
>> In fact, a swiss company is starting to work on a solution for managing
>> cadastral data in colombia, on top of QGIS and Postgis - but it is at the
>> very beginning. If you want to join that effort, I can put you in touch.
> Would I be right in guessing that this is modeled after the QWAT/QGEP
> projects? If so, it sounds great. Lots of fantastic stuff has flowed
> into QGIS upstream as a result of QWAT/QGEP.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/18acabab/attachment.html>
