[Qgis-user] Port number in GetCapabilities
Henrik Uggla
Henrik.Uggla at kristianstad.se
Fri Jun 2 12:57:31 PDT 2017
Thanks for your tip! Adding the port number for every single layer isn't an option though. Also, which I didn't mention, we have also published port 80. We wish to use port 80 for cached content and 81 for non-cached. For both to work simultaneously the URLs in the WMS GetCapabilities response need to be dynamic.
Regards
Henrik
Från: Qgis-user <qgis-user-bounces at lists.osgeo.org> för st_kiefer at web.de <st_kiefer at web.de>
Skickat: den 2 juni 2017 20:21
Till: qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] Port number in GetCapabilities
I read your post just for curiosty, in fact I have no experience with Qgis Server. Otherwise while exploring this feature I found the following in the Documentation:
"If you want QGIS Server to advertise specific request URLs in the WMS GetCapabilities response, enter the corresponding URL in the Advertised URL field."[1] Maybe that helps.
Cheers.
Stefan
[1] http://docs.qgis.org/2.14/en/docs/user_manual/working_with_ogc/ogc_server_support.html#wms-capabilities
Am 02.06.2017 um 15:19 schrieb Henrik Uggla:
Hi!
I've installed Qgis Server on Linux and have set it up to listen on port 81. My problem is that the layer urls in the GetCapabilities response are written without port number. How can I fix this? (I've confirmed that the request Host header includes the port)
regards
HU
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170602/88d067d0/attachment.html>
