[Qgis-user] qad measure command
gam17 at riseup.net
gam17 at riseup.net
Thu Jun 8 23:43:29 PDT 2017
Hi Paolo,
although I am not the plugin creator I am trying to mantain and
support this plugin.
bye
gam17
>> I am trying to implement the measure command in order to show points
>> along a line with the QAD plugin.
>> Somehow it fails to work.
>> I have selected my point layer (editable).
>> I have a line layer (editable).
>> I click on the measure command. I have to select the object to measure,
>> so I try to select the line to measure which is only possible if I
>> select the line layer.
>> When I push on enter it says that only a point layer can be used ????
>> Can anyone help me with this plugin? Is there an English tutorial or
>> help function?
> Hi Reginald,
> unfortunately this plugin is no longer actively maintained (which is a
> pity BTW). It would be necessary for someone to step up and further
> improve it.
> All the best.
