[Qgis-user] Unsupported data source
Andrew Brooks
arb at sat.dundee.ac.uk
Fri Jun 16 09:46:56 PDT 2017
Hi
I'm getting the error "Unsupported data source" when trying to load a
raster layer.
The console windows show no more information about what it doesn't like
about the file :-(
Photoshop and other image viewers are happy to display the images.
The files have all been created by GDAL (via a vrt) so I'm a bit stuck; how
do I find the problem?
gdalinfo reports
Driver: GTiff/GeoTIFF
Files: k-42-141.utm.tif
Size is 3237, 2983
Coordinate System is:
PROJCS["WGS 84 / UTM zone 43N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",75],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","32643"]]
Origin = (71042.208127402234823,4479570.249278925359249)
Pixel Size = (15.035344452565781,-15.035344452565781)
Metadata:
AREA_OR_POINT=Area
COMMENT=CREATOR: XV Version 3.10h Rev: 12/29/94 (PNG patch 1.2arb)
Quality = 100, Smoothing = 0
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 71042.208, 4479570.249) ( 69d56'57.87"E, 40d21'22.88"N)
Lower Left ( 71042.208, 4434719.817) ( 69d58'45.19"E, 39d57'13.81"N)
Upper Right ( 119711.618, 4479570.249) ( 70d31'14.46"E, 40d22'47.81"N)
Lower Right ( 119711.618, 4434719.817) ( 70d32'49.74"E, 39d58'37.55"N)
Center ( 95376.913, 4457145.033) ( 70d14'56.77"E, 40d10' 1.79"N)
Band 1 Block=3237x1 Type=Byte, ColorInterp=Red
Mask Flags: PER_DATASET ALPHA
Band 2 Block=3237x1 Type=Byte, ColorInterp=Green
Band 3 Block=3237x1 Type=Byte, ColorInterp=Blue
Band 4 Block=3237x1 Type=Byte, ColorInterp=Alpha
Thanks
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170616/7305db46/attachment.html>
