[Qgis-user] Split features tool behavior
Bernhard Ströbl
bernhard.stroebl at jena.de
Sun Jun 18 23:28:53 PDT 2017
Hi Andreas,
the color is currently defined in the code. I did not find any setting
to apply. AFAIK only selection color can be defined by the user, but it
might be misleading if you have a selected feature and then have split
parts colored exactly the same. - Wait a minute I just found the
"Highlight color". That would probably work. Will check.
Bernhard
Am 17.06.2017 um 13:22 schrieb Andreas Wicht:
> Hi Bernhard,
> just got to test the new version. It works now as expected.
> Thank you a lot for the good work there!
> Is the highlight color of the currently "selected" part (when you
> choose which part should form the new feature) defined in the code or
> does it use a color, which is set in the QGIS settings?
> cheers
> Andreas
> On 15 June 2017 at 14:33, Bernhard Ströbl <bernhard.stroebl at jena.de> wrote:
>> FYI
>> I implemented a new "Split features" tool in DigitizingTools [1].
>> It should replace "Split features" and "Split parts" in core, see [2]
>> Bernhard
>> [1] http://plugins.qgis.org/plugins/DigitizingTools/
>> [2] https://github.com/bstroebl/DigitizingTools/wiki/Usage
> __________ Information from ESET Mail Security, version of virus signature database 15598 (20170617) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 15606 (20170619) __________
http://www.eset.com
