[Qgis-user] Looking for a function or variable to retrieve canvas extent
Alexandre Neto
senhor.neto at gmail.com
Thu Jun 22 06:25:17 PDT 2017
Great, thanks!
DelazJ <delazj at gmail.com> escreveu no dia quinta, 22/06/2017 às 13:37:
> Actually the expression using a constructed polygon for the canvas extent
> works; I was messing with my polygon construction....
> Looks like canvas related variables are not available from the attribute
> table (using the select by expression or the field calculator) nor from the
> main select by expression tool in toolbar.
> I created a feature request at https://issues.qgis.org/issues/16744.
> Let's see...
> Thanks,
> Harrissou
> 2017-06-21 18:31 GMT+02:00 DelazJ <delazj at gmail.com>:
>> Unfortunately, this was also my conclusion.... And I'm not sure to
>> understand why: is it a choice of design to not expose them or a missing
>> feature (that i can open a report for)?
>> I can do an ovelap check of the feature geometry and a static extent ie,
>> something like
>> within ($geometry, make_polygon(geom_from_wkt('LINESTRING(a closed
>> rectangle based on canvas extent coordinates in status bar)')))
>> and it seems to work once on two (not pretty sure of the result!) but
>> it's STATIC!
>> 2017-06-21 18:05 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
>>> I guess those variables are simply not accessible from the attribute
>>> table window. So there is no way you can use the map canvas for conditional
>>> formatting.
>>> DelazJ <delazj at gmail.com> escreveu no dia quarta, 21/06/2017 às 16:34:
>>>> Thanks Alexandre, but it's too hot to have me doing some maths right
>>>> now :-)
>>>> Actually, what I want to do is to apply some conditional formatting in
>>>> the attribute table using the canvas extent values but for some reason,
>>>> those variables you mentioned are not exposed in that expression builder
>>>> dialog.
>>>> There's also a @map_extent variable in master which returns the
>>>> geometry (for composer map only? or canvas also?) but like others, it's not
>>>> exposed.
>>>> 2017-06-21 17:10 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
>>>>> How about using the map_extent_center, map_extent_height and
>>>>> map_extent_width to create a geometry?
>>>>> DelazJ <delazj at gmail.com> escreveu no dia quarta, 21/06/2017 às 14:53:
>>>>>> Hi,
>>>>>> In the Expression dialog, is there a function or a variable that can
>>>>>> return the current map canvas?
>>>>>> I would like for example apply a value to all features that fall
>>>>>> within the current map canvas but fail to find the right combination (if
>>>>>> ever possible).
>>>>>> Thanks for any hint,
>>>>>> Harrissou
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Alexandre Neto
>>>>> @AlexNetoGeo
>>>>> http://sigsemgrilhetas.wordpress.com
>>>>> http://gisunchained.wordpress.com
>>> Alexandre Neto
>>> @AlexNetoGeo
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170622/f34e0778/attachment.html>
