[Qgis-user] Mini dump when adding SQL layers QGIS 2.18.8
Martin Bain
Martin.Bain at lismore.nsw.gov.au
Sun Jun 25 15:47:28 PDT 2017
Hi Johanna,
2.18.8 was quickly replaced by 2.18.9 I think it had some issues - I don't know if any of them relate to your problem.
Are you adding the layers from the browser window or the add layer menu?
Are you using a named ODBC DSN or putting the SQL Server Host details directly into QGIS? I had mini dumps when I was using named ODBC connections.
I'm afraid the only thing I can suggest, if you haven't already tried, is to try switching the way you are connecting and adding the layers.
Cheers,
Martin.
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Johanna Botman
Sent: Monday, 26 June 2017 8:18 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Mini dump when adding SQL layers QGIS 2.18.8
We have recently upgraded to 2.18.8 and I am struggling with adding data from MS SQL. I get a mini dump every time.
I still have 2.14 installed on my Windows 7 64 bit machine and I don't have the same issue with that version. Any tips for troubleshooting?
Johanna Botman
Asset & GIS Officer | Melton City Council
[Melton logo colour - low res] P: 03 9747 7209
E: johannab at melton.vic.gov.au
W: melton.vic.gov.au
The information in this message is privileged and confidential, intended only for the use of the individual or entity named above. If you are not the intended recipient you are hereby notified to delete the message and that any dissemination, copying or use of its content is strictly prohibited. If you have received this message in error please notify the Melton City Council.
This email is intended for the named recipient only. The information it contains may be confidential. If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it. If you have received this email in error, please contact the sender immediately and delete the message.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170625/4d1e7fde/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170625/4d1e7fde/attachment.jpg>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170625/4d1e7fde/attachment-0001.jpg>
