[Qgis-user] Field Calculator behavior
Andreas Wicht a.wicht at gmail.com
Wed Mar 1 23:37:48 PST 2017
On 1 March 2017 at 15:51, DelazJ <delazj at gmail.com> wrote:
> Hi,
> Did you consider using the quick field calculation bar
> http://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/attribute_table.html#the-quick-field-calculation-bar?
> It's supposed to be a kind of shortcut to field calculator dialog.
> Harrissou
Thank you for the tip, Harrissou. Certainly a nice workaround for the
less complex stuff. Will see how feasible it is.
And as there is already a feature request, it will be implemented
sooner or later as I guess it is not a huge change code-wise.
