[Qgis-user] QGOS maps fort Garmin GPS
Brent Fraser bfraser at geoanalytic.com
Sun Mar 5 15:23:38 PST 2017
Stephen,
   Based on the info from SCRD, I changed the name of Joe Smith Creek to
Molyneux Creek.
Best Regards,
Brent Fraser
On 3/5/2017 3:41 PM, Brent Fraser wrote:
> Hey Stephan,
>   This discussion may belong on the OSM-Canada mailing list
> (https://lists.openstreetmap.org/listinfo/talk-ca) so others can comment.
>   All maps contain errors, some intentional, others by mistake, and
> still others due to the passage of time.  The great thing about OSM is
> you can correct them!  The OSM community holds local knowledge in very
> high regard, and one of the basic guidelines is "If you think the data
> is wrong, change it."  I find the quality of the data very good,
> perhaps due to the majority of the editors have a passion for mapping.
>   I had a look at Joe Smith Creek in OSM.  It was imported from Canvec
> v10 (the Fed 1:50k data), and named the same on the BC 1:20k sheet. If
> you like, I could change the name...
> Best Regards,
> Brent Fraser
> On 3/5/2017 2:01 PM, Stephen Wandling wrote:
>> Phil,
>> For a government mapping agency to have a problem, it first has to
>> exist.  I am told that in 1992, British Columbia dismantled it's
>> cartography department and fired all of the cartographers. I am also
>> told that no work had been done on any of the 20K maps in the prior
>> 10 years.  So, only the private resource extraction corporations have
>> access to up-to-date digital data and at a price that I certainly can
>> not afford.
>> I had a look at OSM mountain biking maps last night, your second link
>> below.  I could see that someone had probably 'walked' what they
>> thought was Joe Smith Creek with their GPS, and extended what had
>> been on the base map.  First, that is Molyneux creek and not Joe
>> Smith, the base map was wrong and secondly that creek comes from a
>> large number of forks up the mountain, so they only dealt with a
>> small percentage of it's reach.  My immediate thought was "This is
>> Wikipedia for Cartography!". Errors laid upon errors. No use of local
>> knowledge or the Streams shape files available on the Regional
>> District's site.
>> That is a can of worms I am not interested in delving into.
>> Cheers,
>> Stephen
>> On 04/03/2017 8:28 PM, Phil (The Geek) Wyatt wrote:
>>> No problems Stephen,
>>> Unfortunately many government agencies can't keep up with edits of
>>> new tracks/trails but that is the beauty of Open Street Map. Your
>>> contribution, by adding tracks, means that all the folks making
>>> derivative products get the benefits. You also get the benefit of
>>> their knowledge in the creation of products to suit your GPS. Indeed
>>> you can even use OSM mapping as a background in QGIS so you get the
>>> same benefits immediately.
>>> If you have some GPS files, drop me a few and I will get them loaded
>>> for you to get you started.
>>> The Mountain bike community are quite active in some areas and have
>>> great wiki information on tagging for trails
>>> http://wiki.openstreetmap.org/wiki/Mountain_biking
>>> https://openmtbmap.org/
>>> Cheers - Phil
>>> -----Original Message-----
>>> From: Stephen Wandling [mailto:swandling at gmail.com]
>>> Sent: Sunday, March 5, 2017 12:14 PM
>>> To: Phil (The Geek) Wyatt
>>> Cc: qgis-user at lists.osgeo.org
>>> Subject: Re: [Qgis-user] QGOS maps fort Garmin GPS
>>> Phil,
>>> Someone suggested the same OSM approach in an off list email. Here
>>> was my response:
>>>> I have just taken a look at OSM, and the maps there, for my area of
>>>> interest, are taken from the ancient (pre 1992) British
>>>> Columbia/Canada maps that are very incomplete and riddled with errors.
>>>> It is because there are no accurate maps of this area that I resumed
>>>> my struggles with GIS and have been making maps and having them
>>>> plotted.
>>> The areas I am creating maps for are entirely forest areas, with
>>> streams, trails, roads, parks and that is about it.  No buildings,
>>> streets, etc.
>>> In the last 20 years or so the mountain bikers and hikers, have put
>>> in and documented hundreds of kilometers of trails along this
>>> coast.  The OSM maps have a single digit percentage of what is here
>>> now.  And many they do have have been obliterated by clear cut
>>> logging operations.
>>> I have been making simple maps, that meet my needs, and having them
>>> plotted at a local facility for $15 each, which is cheaper than the
>>> incomplete/error ridden maps that one can purchase.  I use these
>>> maps to travel through this area on foot.
>>> Now I wanted a better map for my GPS.  So far, no luck.
>>> Stephen
>>> On 04/03/2017 4:28 PM, Phil (The Geek) Wyatt wrote:
>>>> Depending on the size of the area involved and how 'custom' your maps
>>>> are likely to be you may be better off looking at solutions from OSM.
>>>> There are many sites that create files suitable for Garmin GPS
>>>> http://garmin.openstreetmap.nl/
>>>> If the areas are small you could also create KMZ (Google Earth
>>>> Files) and transfer them to your garmin device. These can be
>>>> created in QGIS. Look at the plugin GarminCustomMap.
>>>> Cheers - Phil
>>>> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf
>>>> Of Stephen Wandling
>>>> Sent: Sunday, March 5, 2017 11:03 AM
>>>> To: qgis-user at lists.osgeo.org
>>>> Subject: [Qgis-user] QGOS maps fort Garmin GPS
>>>> I am running QGIS 2.18.3 and am at a very early learning stage.  I
>>>> wish to create simple maps, with 2 or 3 shape files for my Garmin
>>>> GPSMaps 76CSx.  This map would consist of Trails and Streams shp
>>>> files and maybe Contours.  It would also be accepted by Mapsource
>>>> and Base Camp.
>>>> There were some tutorials that seemed like they were what I wanted,
>>>> but they all failed in one regard or another: 1.) They were using
>>>> an 'ancient' version of qgis.  2.) The maps they produced worked in
>>>> just about every Garmin GPS except the one I own.  3.) They use a
>>>> plug-in with a disclaimer that it will demolish my data.  There
>>>> were other issues, but my memory fails me.
>>>> If someone out there is familiar with my situation (and possibly
>>>> has the same GPS) and can either point me to a site I missed, or
>>>> outline the steps for me, I would be grateful.
>>>> [If it is easier to do in ArcMap, I have access to the ESRI software
>>>> also.]
>>>> Please keep in mind that while I have a general idea about GIS work
>>>> and have been making some maps, for plotting, that satisfy my
>>>> needs, I get very lost when I am subjected to acronyms and
>>>> technical jargon.  If is not clear and straightforward, it will
>>>> probably be wasted on me.
>>>> TIA,
>>>> Stephen
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
