[Qgis-user] GEO-REFERENCER not working
DelazJ delazj at gmail.com
Tue Mar 14 07:34:25 PDT 2017
If you have used the georeferencer with two screens connected to your
computer, it may happen that its dialog is left on the other screen
(ignoring that you have only one screen now). Hence, if it could be the
case and that you can try with a second screen, check it....
Regards,
Harrissou
2017-03-14 15:22 GMT+01:00 civil142 <Ian.kirk-ellis at rodgersleask.co.uk>:
> Hi Nicolas,
> I removed all the .qgis2 folders within my login, but not from other
> users, I would imagine I would have to be logged in as them and as some of
> them have now left the company this may be difficult. I removed the
> registry keys.
> I did a full uninstall using the uninstall routine, but also used (after
> this failing) further uninstall software to get rid of remaining elements.
> Many thanks,
> Ian
> *From:* Nicolas Cadieux [via OSGeo.org] [mailto:ml-node+[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5312261&i=0>]
> *Sent:* 14 March 2017 14:08
> *To:* Ian kirk-ellis
> *Subject:* Re: GEO-REFERENCER not working
> Hi,
> Did you manually remove all .qgis2 folders for all the users in the
> computers? If you have have 3 users , you have 3 .qgis2 folders.  Did you
> destroy the registry keys?
> You talk about a full uninstall, what procedure did you use? You must have
> something lying around giving you problems.
> Nicolas
> Le 14 mars 2017 à 07:27, civil142 [via OSGeo.org] <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5312256&i=0>> a écrit :
> Hi Nicolas,
> It was working originally and I used it a lot. I have uninstalled QGIS
> several times and replaced with several subsequent versions but it still
> remains broken. When I click the geo referencer button, nothing happens.
> I have to use QGIS on a new machine to use the geo reference function. You
> would think that a full uninstall and a reinstall would fix any such
> issues, however this persists.
> Kind regards,
> Ian
> *If you reply to this email, your message will be added to the discussion
> below:*
> http://osgeo-org.1560.x6.nabble.com/GEO-REFERENCER-not-
> working-tp5271041p5312222.html
> To start a new topic under QGIS - User, email [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5312256&i=1>
> To unsubscribe from QGIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> below:*
> working-tp5271041p5312256.html
> To unsubscribe from GEO-REFERENCER not working, click here.
> NAML
> *Disclaimer*
> The information contained in this communication from the sender is
> confidential. It is intended solely for use by the recipient and others
> authorized to receive it. If you are not the recipient, you are hereby
> notified that any disclosure, copying, distribution or taking action in
> relation of the contents of this information is strictly prohibited and may
> be unlawful.
> This email has been scanned for viruses and malware, and may have been
> automatically archived by *Mimecast Ltd*, an innovator in Software as a
> Service (SaaS) for business. Providing a *safer* and *more useful* place
> for your human generated data. Specializing in; Security, archiving and
> compliance. To find out more Click Here
> <http://www.mimecast.com/products/>.
> View this message in context: RE: GEO-REFERENCER not working
> <http://osgeo-org.1560.x6.nabble.com/GEO-REFERENCER-not-working-tp5271041p5312261.html>
> Sent from the QGIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html> at
> Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170314/6a9adc2d/attachment.html>
