[Qgis-user] Help for crossing data with fragstats and QGIS
Philip Barlow philipb at pembrokeshirecoast.org.uk
Mon Mar 20 08:58:57 PDT 2017
Hi Mariana,
Oh I see, it isn’t exporting the data that you want to map just a 1 or 0?
If you can get the data out and have some geometry you can relate/join it to…  I’m not familiar with that piece of software unfortunately.
Is there anything in its documentation that can help you?  http://www.umass.edu/landeco/research/fragstats/fragstats.html
Phil
From: Mariana Buzzi [mailto:marianabuzzi86 at gmail.com]
Sent: 20 March 2017 15:42
To: Philip Barlow
Cc: qgis-user
Subject: Re: [Qgis-user] Help for crossing data with fragstats and QGIS
Hi Phil! Thanks for you answer!
The binary raster consists of patches and a matrix, this is the one used as an input to be able to enter the Frastasts and calculate the metric of landscape. As you will see in the attached image, the fragstasts generates me as a result a table (at class level, patch level and landscape level). What I need is to generate a map (for example showing the patch density) depending on the result generated by the Fragstats. My problem is that I do not know how to transform the table of fragstats to a map
2017-03-20 12:26 GMT-03:00 Philip Barlow <philipb at pembrokeshirecoast.org.uk<mailto:philipb at pembrokeshirecoast.org.uk>>:
Hi Marianna,
From what you are saying it sounds like you have a raster with pixels/grid values 0 or a 1?
I think what I would do is some ā€ binningā€¯.  You can create grids to the desired size with the mmqgis plugin so you could make a 100 hectare grid and then run the zonal statistics plugin to sample your raster, that will append statistics from the raster to the grid for each grid square.  You could then style (graduated) your grid according to the ā€ countā€¯ column to give you a kind of heat map.
Regards
Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] On Behalf Of Mariana Buzzi
Sent: 20 March 2017 14:12
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Help for crossing data with fragstats and QGIS
Good morning. I am trying to make maps in QGIS with information provided through landscape metrics obtained through the program fragstats. The input used to enter Fragstats is a sorted raster generated in QGIS; The raster is made up of two values: 1 (wells and paths) and 0 (matrix). My problem is that I do not know how to curl the table with the results of the metrics that Fragstats gives me to be able to make a map. For example a map with patch density (number of patches per 100 hectares).
I hope you can help me. Thank you!
Mariana
Universidad Nacional de la Patagonia San Juan Bosco
Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
The Authority is happy to communicate in Welsh or English
Website www.pembrokeshirecoast.org.uk<http://www.pembrokeshirecoast.org.uk>
Follow us on Twitter<http://twitter.com/PembsCoast>
Join us on Facebook<http://www.facebook.com/group.php?gid=26330984774&ref=ts>
Watch us on Youtube <http://www.youtube.com/user/pcnpa2008#p/u/0/Tw8Udou0p5k>
Look at us on Flickr<http://www.flickr.com/photos/pembrokeshirecoast/>
This email and any attached files should only be read by those persons to whom
they are addressed and be used by them only for their intended purpose.
If you are not the intended recipient please destroy all copies and inform the
sender by return email.
Please note that the contents of this email may be subject to public disclosure
under the Freedom of Information Act 2000 and therefore the confidentiality of
this message and any reply cannot be guaranteed.
For further information on the PCNPA please visit our website at www.pembrokeshirecoast.org.uk<http://www.pembrokeshirecoast.org.uk>
Please consider the environment before printing this email
Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw ffeiliau sydd
ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y bwriadwyd hwy.
Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal ā dinistrio pob copi a rhoi
gwybod i’r anfonwr gyda throad yr e-bost.
Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei ddatgelu i’r cyhoedd o
dan Ddeddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd y neges hon
nac unrhyw ateb.
Am ragor o wybodaeth am APCAP ymwelwch ā’n gwefan ar www.pembrokeshirecoast.org.uk<http://www.pembrokeshirecoast.org.uk>
Ystyrier yr amgylchedd cyn argraffu’r e-bost hwn os gwelwch yn dda.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170320/07f5a8a2/attachment.html>
