[Qgis-user] QGIS airlines: connecting airports with lines ?
C Hamilton adenaculture at gmail.com
Mon Mar 27 05:35:20 PDT 2017
The "XY to Line" tool in the "Shape Tools" plugin can draw the lines. Just
prepare your data so that there are starting and ending latitudes and
longitudes and "XY to Line" will do the rest. It draws the shortest path
between the two points which gives the curved appearance.
Good luck,
Calvin
On Mon, Mar 27, 2017 at 1:25 AM, Alex Mandel <tech_dev at wildintellect.com>
wrote:
> It's not super hard.
> 1. Download the data
> 2. Import it to GIS (probably comes in text file, so some conversion
> will be needed.)
> 3. Densify the lines, or create lines between the pairs of airports.
> Point 2 Lines plugin should help. You need to make sure to add nodes
> along the way (Densify), otherwise the lines won't curve nicely. There's
> a little trial and error to get them dense enough without making to many
> nodes.
> I used this data set for a cartography class 5+ years ago, it's a fun
> one. You can see a couple of examples here
> http://geography.ucdavis.edu/gallery/classes/geo-290-f10-cartography
> Enjoy,
> Alex
> On 03/25/2017 05:06 PM, Falk Huettmann wrote:
> > Hi there,
> > I have a question, if I may:
> > at the following website
> > http://openflights.org/data.html
> > there are these maps of airlines, connecting airports.
> > http://openflights.org/demo/openflights-routedb-2048.png
> > The actual map and code can apparently be bought,
> > but instead I am looking for a self-made solution (I do not like how
> people
> > cash in on a GIS bottleneck).
> > Would you perhaps know how that map can be done, e.g.
> > in QGIS or related in an OpenGIS framework or code?
> > Thanks so much; kind regards
> >      Falk
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170327/60ab27df/attachment.html>
