[Qgis-user] qgis installation problems
Angelos Tzotsos gcpp.kalxas at gmail.com
Wed Mar 29 04:49:33 PDT 2017
On top of that, there is a problem in the Ubuntu libtiff recent patch,
which breaks QGIS.
https://trac.osgeo.org/osgeo/ticket/1897
On 03/29/2017 02:33 PM, Randal Hale wrote:
> If I understand correctly there is a new version of GDAL in UbuntuGIS
> that is causing a conflict. They are working to resolve it. For
> instance - I am on 2.18.4 and can't upgrade currently. I would install
> just from the QGIS Repository and wait a bit - then upgrade to
> UbuntuGIS in a few days.
> Randy
> On 03/29/2017 05:26 AM, Filipe Dias wrote:
>> Hi
>> I am on Ubuntu 16.04 and trying a fresh installtion of the latest
>> 2.18.x version with ubuntugis dependencies. I have both "ubuntugis
>> unstable" and http://qgis.org/ubuntugis". However this happens:
>> fd at fd-XPS:~$ sudo apt-get install qgis python-qgis
>> Reading package lists... Done
>> Building dependency tree
>> Reading state information... Done
>> Some packages could not be installed. This may mean that you have
>> requested an impossible situation or if you are using the unstable
>> distribution that some required packages have not yet been created
>> or been moved out of Incoming.
>> The following information may help to resolve the situation:
>> The following packages have unmet dependencies:
>>  python-qgis : Depends: libqgis-analysis2.18.5 but it is not going to
>> be installed
>>                Depends: libqgis-server2.18.5 but it is not going to
>> be installed
>>  qgis : Depends: gdal-abi-2-1-2 but it is not installable
>>         Depends: libqgis-analysis2.18.5 but it is not going to be
>> installed
>>         Depends: libqgis-app2.18.5 but it is not going to be installed
>>         Recommends: qgis-plugin-globe but it is not going to be
>> installed
>>         Recommends: qgis-plugin-grass but it is not going to be
>> installed
>>         Recommends: qgis-provider-grass but it is not going to be
>> installed
>> E: Unable to correct problems, you have held broken packages.
>> Am I doing something wrong?
>> Thanks
>> Cheers
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170329/b51e8884/attachment.html>
