[Qgis-user] EasyCustomLabel
Janmaat, Johannus
John.Janmaat at ubc.ca
Wed May 3 06:33:08 PDT 2017
Hello Werner,
Thanks for the reply. I checked the settings. Same repository. I used http://whatismyipaddress.com/proxy-check and neither my Windows machine nor Linux machine are behind a proxy. Both are using QGIS 2.18.7 (Las Palmas).
The plugin manager shows 474 plugins total for my Windows machine, and 473 for my Linux machine. When I search in the plugins list with 'easy' the only one that isn't there on the Linux machine is EasyCustomLabel.
Any further suggestions?
The Linux system is openSuSE Leap 42.2.
John.
-----Original Message-----
From: Werner Macho [mailto:werner.macho at gmail.com]
Sent: May-02-17 10:51 PM
To: Janmaat, Johannus <John.Janmaat at ubc.ca>
Cc: qgis-user at lists.osgeo.org; Suzan Lapp <slapp at climaterra.ca>
Subject: Re: [Qgis-user] EasyCustomLabel
Hi!
Are the settings in the plugin installer options the same?
Are you behind a proxy (where one computer has the proxy settings and the other does not)?
Is the path to the plugin repository the same?
Is the QGIS Version the same?
The plugin is there . and since a few days also for QGIS3 .. so you should be able to install it..
regards
Werner
On Wed, May 3, 2017 at 3:21 AM, Janmaat, Johannus <John.Janmaat at ubc.ca> wrote:
> Hello,
> I am trying to install the plugin EasyCustomLabel on a Linux install
> of QGIS. It does not show up on the plugin manager list. It does
> show up on a windows install.
> Can someone help me figure out how to install it in Linux?
> Thanks,
> John.
> Dr. John Janmaat
> Associate Professor of Economics and RIC Chair in Water Resources and
> Ecosystem Sustainability
> Economics (unit 8), I.K. Barber School of Arts and Sciences
> The University of British Columbia
> 3187 University Way, Kelowna, British Columbia, V1V 1V7
> (250)807-8021
> Qgis-user mailing list
