[Qgis-user] Problems installing Mac version from homebrew
Larry Shaffer
larrys at dakotacarto.com
Wed May 10 14:53:23 PDT 2017
Hi Jesus,
Please follow the standard means of installing the formula:
brew install osgeo/osgeo4mac/qgis2
which will automatically 'tap' the osgeo/homebrew-osgeo4mac tap (code repo
of formulae).
If that does not work, then there is something wrong with your basic
install of Homebrew.
If you feel it is still an issue with the OSGeo4Mac tap, please report the
issue here:
https://github.com/OSGeo/homebrew-osgeo4mac/issues
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
Boundless Desktop and QGIS Support/Development
Boundless Spatial - http://boundlessgeo.com
lshaffer at boundlessgeo.com
On Tue, May 9, 2017 at 6:03 PM, Jesús Lopez <jesusl.temez at gmail.com> wrote:
> When I try to install last Mac version from Osgeo brew with brew install
> https://raw.github.com/osgeo/homebrew-osgeo4mac/master/qgis2.rb I get
> this:
> /System/Library/Frameworks/Ruby.framework/Versions/2.0/
> usr/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:55:in `require':
> cannot load such file -- mach (LoadError)
> from /System/Library/Frameworks/Ruby.framework/Versions/2.0/
> from /usr/local/Library/Homebrew/extend/pathname.rb:2:in `<top
> (required)>'
> from /usr/local/Library/Homebrew/global.rb:3:in `<top (required)>'
> from /usr/local/Library/brew.rb:16:in `<main>’
> and nothing happens….
> I get the same outuput with brew install qgis2
> Any idea what am I doing wrong?
> Thanks in advance.
> Jesus
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170510/b6c2a147/attachment.html>
