[Qgis-user] Magnetic declination
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed May 17 06:52:53 PDT 2017
https://www.youtube.com/watch?v=7TN3toqcyks
> Le 17 mai 2017 à 09:02, Tudorache, Marian [via OSGeo.org] <ml+s1560n5320815h26 at n6.nabble.com> a écrit :
> Hi everyone,
> I have a map build in True Geographic North.
> I have used the Magnetic Declination plugin build by Aldo Scorza, to calculated magnetic declination on various points on the map.
> I would like to know if there is a way to rotate the map on the fly with declination angle.
> Thanks,
> Marian
> ________________________________
> This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
> Qgis-user mailing list
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Magnetic-declination-tp5320815.html
> To start a new topic under QGIS - User, email ml+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from QGIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Magnetic-declination-tp5320815p5320828.html
Sent from the QGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170517/3fba3777/attachment.html>
