[Qgis-user] Magnetic declination
Alexandre Neto
senhor.neto at gmail.com
Wed May 17 23:16:01 PDT 2017
That is a very strange request (to only rotate one layer), but anyway.
You can use the layer's draw effects(layer properties, style, layer
rendering.
Use the transform effect.
Hope it helps
A qua, 17/05/2017, 16:50, Tudorache, Marian <Marian.Tudorache at navcanada.ca>
escreveu:
> Thank you Nicolas,
> I have seen this video. The rotation is applied to the whole canvas.
> I forgot to mention but I want to apply the rotation for one layer only.
> The other layers I want to keep un-rotated.
> Thanks,
> Marian
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Nicolas Cadieux
> *Sent:* May-17-17 9:53 AM
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Magnetic declination
> https://www.youtube.com/watch?v=7TN3toqcyks
> Le 17 mai 2017 à 09:02, Tudorache, Marian [via OSGeo.org] <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5320828&i=0>> a écrit :
> Hi everyone,
> I have a map build in True Geographic North.
> I have used the Magnetic Declination plugin build by Aldo Scorza, to
> calculated magnetic declination on various points on the map.
> I would like to know if there is a way to rotate the map on the fly with
> declination angle.
> Thanks,
> Marian
> ________________________________
> This electronic message, as well as any transmitted files included in the
> electronic message, may contain privileged or confidential information and
> is intended solely for the use of the individual(s) or entity to which it
> is addressed. If you have received this electronic message in error please
> notify the sender immediately and delete the electronic message. Any
> unauthorized copying, disclosure or distribution of the electronic message
> is strictly forbidden. NAV CANADA accepts no liability for any damage
> caused by any virus and/or other malicious code transmitted by this
> electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels destinés à
> l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si
> vous avez reçu ce message électronique par erreur, veuillez en informer
> l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation
> ou distribution du présent message électronique est strictement interdite.
> NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout
> virus ou autre programme malveillant transmis par ce message électronique.
> Qgis-user mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5320815&i=0>
> *If you reply to this email, your message will be added to the discussion
> below:*
> http://osgeo-org.1560.x6.nabble.com/Magnetic-declination-tp5320815.html
> To start a new topic under QGIS - User, email [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5320828&i=1>
> To unsubscribe from QGIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Magnetic declination
> <http://osgeo-org.1560.x6.nabble.com/Magnetic-declination-tp5320815p5320828.html>
> Sent from the QGIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html> at
> Nabble.com.
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170518/583bc16e/attachment.html>
