[Qgis-user] Moving selected feature to the top of attribute table does not seem to work in 2.18.7
Luigi Pirelli luipir at gmail.com
Thu May 18 02:00:30 PDT 2017
Can you try to compile from this source code branch?
https://github.com/qgis/QGIS/tree/release-2_18
just to be sure that the issue has completly fixed.
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 18 May 2017 at 10:31, Hernán De Angelis <dhdeangelis at gmail.com> wrote:
> Thank you for your fast response, Luigi.
> I understand. I can wait for the next release, no problem. As for the
> <someValue> question, I will have a look and come back with whatever I find,
> but when I found this I wasn't working on any particular project nor using
> composer either.
> Cheers
> Hernán
> On Thu, May 18, 2017 at 10:12 AM, Luigi Pirelli <luipir at gmail.com> wrote:
>> fixed during the hackfest on current 2.18 code (you have to wait for
>> 2.18.8... or update to the latest 2.18 code not the tagged release
>> version)
>> https://github.com/qgis/QGIS/pull/4306
>> and 3.0
>> https://github.com/qgis/QGIS/pull/4444
>> btw there are some simple workaround to fix temporarly waiting the patch
>> release
>> workaround 1) in the attribute table, apply a sort on some column =>
>> apply sortOnTop
>> workaround 2) in your project xml file you should have a tag as:
>> <attributetableconfig ... sortOrder="<someValue>" >
>> in your case <someValue> is something different from 0 (Ascending) or
>> 1 (Descending)... fix it and sortOnTop will be back :)
>> btw, pelase let me knwo what value is in <someValue>, because is not
>> clear who's set it to a strange value (probably the composer)
>> cheers
>> Luigi Pirelli
>> On 18 May 2017 at 10:03, Hernán De Angelis <dhdeangelis at gmail.com> wrote:
>> > Hi
>> > Yesterday I compiled from source QGIS 2.18.7 in openSUSE Leap 42.2
>> > Linux.
>> > Everything went fine and there were no problems with the compilation.
>> > However, when using the new installation I realized that the function
>> > that
>> > allows to move the attribute row of a selected feature to the top of the
>> > attribute table does not seem to work. This problem was not present in
>> > my
>> > previously installed version (2.18.6), nor in another machine I use
>> > (QGIS
>> > 2.14.2, Windows 7) using the same data. I wonder if any other users are
>> > experiencing this in 2.18.7, or there is just something wrong with my
>> > particular installation.
>> > Regards,
>> > Hernán
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
