[Qgis-user] Moving selected feature to the top of attribute table does not seem to work in 2.18.7
Hernán De Angelis
dhdeangelis at gmail.com
Fri May 19 10:01:03 PDT 2017
I have now tried several times to compile code from github but I keep
getting cryptic errors, apparently not related to the issue mentioned in
this thread (see below).Anyhow, it has been pointed as solved, so I will
wait.
Just in case you are curious, the error I get is:
[ 61%] Building CXX object src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o
/usr/local/src/QGIS-release-2_18/src/app/qgisapp.cpp: In member function
‘QgsVectorLayer* QgisApp::addVectorLayer(const QString&, const QString&,
const QString&)’:
/usr/local/src/QGIS-release-2_18/src/app/qgisapp.cpp:9318:52: error:
‘QStringLiteral’ was not declared in this scope
layer->setName( QStringLiteral( "%1 %2 %3" ).arg( layer->name(),
elements.at( 1 ), elements.at( 3 ) ) );
src/app/CMakeFiles/qgis_app.dir/build.make:847: recipe for target
'src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o' failed
make[2]: *** [src/app/CMakeFiles/qgis_app.dir/qgisapp.cpp.o] Error 1
CMakeFiles/Makefile2:2726: recipe for target
'src/app/CMakeFiles/qgis_app.dir/all' failed
make[1]: *** [src/app/CMakeFiles/qgis_app.dir/all] Error 2
Makefile:160: recipe for target 'all' failed
make: *** [all] Error 2
Regards and thanks for the help!
/H.
On Thu, May 18, 2017 at 11:00 AM, Luigi Pirelli <luipir at gmail.com> wrote:
> Can you try to compile from this source code branch?
> https://github.com/qgis/QGIS/tree/release-2_18
> just to be sure that the issue has completly fixed.
> regards
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> * https://www.packtpub.com/big-data-and-business-
> intelligence/mastering-qgis-second-edition
> On 18 May 2017 at 10:31, Hernán De Angelis <dhdeangelis at gmail.com> wrote:
> > Thank you for your fast response, Luigi.
> > I understand. I can wait for the next release, no problem. As for the
> > <someValue> question, I will have a look and come back with whatever I
> find,
> > but when I found this I wasn't working on any particular project nor
> using
> > composer either.
> > Cheers
> > Hernán
> > On Thu, May 18, 2017 at 10:12 AM, Luigi Pirelli <luipir at gmail.com>
> wrote:
> >> fixed during the hackfest on current 2.18 code (you have to wait for
> >> 2.18.8... or update to the latest 2.18 code not the tagged release
> >> version)
> >> https://github.com/qgis/QGIS/pull/4306
> >> and 3.0
> >> https://github.com/qgis/QGIS/pull/4444
> >> btw there are some simple workaround to fix temporarly waiting the patch
> >> release
> >> workaround 1) in the attribute table, apply a sort on some column =>
> >> apply sortOnTop
> >> workaround 2) in your project xml file you should have a tag as:
> >> <attributetableconfig ... sortOrder="<someValue>" >
> >> in your case <someValue> is something different from 0 (Ascending) or
> >> 1 (Descending)... fix it and sortOnTop will be back :)
> >> btw, pelase let me knwo what value is in <someValue>, because is not
> >> clear who's set it to a strange value (probably the composer)
> >> cheers
> >> Luigi Pirelli
> >> On 18 May 2017 at 10:03, Hernán De Angelis <dhdeangelis at gmail.com>
> wrote:
> >> > Hi
> >> > Yesterday I compiled from source QGIS 2.18.7 in openSUSE Leap 42.2
> >> > Linux.
> >> > Everything went fine and there were no problems with the compilation.
> >> > However, when using the new installation I realized that the function
> >> > that
> >> > allows to move the attribute row of a selected feature to the top of
> the
> >> > attribute table does not seem to work. This problem was not present in
> >> > my
> >> > previously installed version (2.18.6), nor in another machine I use
> >> > (QGIS
> >> > 2.14.2, Windows 7) using the same data. I wonder if any other users
> are
> >> > experiencing this in 2.18.7, or there is just something wrong with my
> >> > particular installation.
> >> > Regards,
> >> > Hernán
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170519/bb5359ab/attachment.html>
