[Qgis-user] bring selected feature to the top
Richard Duivenvoorde
rdmailings at duif.net
Mon May 22 00:23:02 PDT 2017
On 21-05-17 15:42, Willem Coetzer wrote:
> I have a point shapefile containing points that may be stacked precisely
> on top of one another, which means that when I make a selection in the
> attribute table, I don’t always see the selected point. Is there a
> ‘bring selected feature to top’ button?
Not that I know, but for polygons you could temporarily make layer half
transparent, then you can see the selections 'trough' the overlaying
one. The map/node tools are just working then.
With points this more or less works also, depending on the shape/color
you use. So not sure if that would work...
But maybe we could do a feature request to copy the selected points as
'selected points' or so? Though I do see the problem there that this
maybe can be resource hungry when selecting a lot of points...
Regards,
