[Qgis-user] Clipping a QgsVectorLayer object of type LineString with a QgsVectorLayer object of type Polygon
Lukas Winiwarter lukas.winiwarter at geo.tuwien.ac.at
Mon May 22 00:37:54 PDT 2017
Hi Marian,
I suppose the QGIS Clip algorithm does not work on "memory"-Layers, i.e.
Layers that are not written to disk. You can either try to save your
layer as a shapefile and then run the clipping algorithm, or iterate
over the geometries and use the QgsGeometry.Intersection(QgsGeometry)
function
(https://qgis.org/api/classQgsGeometry.html#a6ca0f918c7c67aff8ac9e0094707c99e).
This could be something like this (not tested, just off the top of my head):
clipPoly = clipLayer.getFeatures()[0].geometry() # get the first feature
(assumes only one polygon)
for input_feat in inputLayer.getFeatures():
     input_geom = input_feat.geometry()
     output_geom = input_geom.Intersection(clipPoly)
     # do something with output_geom, e.g. write to a layer
Best regards,
Lukas
On 19.05.2017 16:02, Tudorache, Marian wrote:
> *Hi,*
> I have tried to run clipping processing algorithm and it fails.
> First version:
> srs = qgis.core.QgsCoordinateReferenceSystem(4019, qgis.core.
> QgsCoordinateReferenceSystem.EpsgCrsId)
> #Input Layer
> inputLayer = qgis.core.QgsVectorLayer(shapeFileLocation +
> “/inputLineString.shp”, “inputLineString”, “ogr”)
> inputLayer.setCrs(srs)
> Clipping Layer:
> clipLayer =
> qgis.core.QgsVectorLayer(“Polygon?crs={0}”.format(srs.authid())
> #algorithm to add a clipping polygon feature
> #the algorithm works because I tested with clipLayer.getFeatures() and
> I was able to extract the geometry and points
> #calling processing algorithm.
> processing.runalg(‘qgis.clip’, inputLayer, clipLayer, “output.shp”)
> The error:
> Unable to execute algorithm
> Wrong parameter value: Polygon?crs=ESPG:4019
> Any idea why is not working?
> Thank you,
> Marian
> This electronic message, as well as any transmitted files included in
> the electronic message, may contain privileged or confidential
> information and is intended solely for the use of the individual(s) or
> entity to which it is addressed. If you have received this electronic
> message in error please notify the sender immediately and delete the
> electronic message. Any unauthorized copying, disclosure or
> distribution of the electronic message is strictly forbidden. NAV
> CANADA accepts no liability for any damage caused by any virus and/or
> other malicious code transmitted by this electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels
> destinés à l’usage exclusif des personnes ou des organismes à qui ils
> s’adressent. Si vous avez reçu ce message électronique par erreur,
> veuillez en informer l’expéditeur immédiatement et supprimez le. Toute
> reproduction, divulgation ou distribution du présent message
> électronique est strictement interdite. NAV CANADA n’assume aucune
> responsabilité en cas de dommage causé par tout virus ou autre
> programme malveillant transmis par ce message électronique.
> Qgis-user mailing list
Lukas Winiwarter                        TU Wien,
Stud. Ass.                              Department of Geodesy and
Tel: +43-(0)1-58801-12246               Geoinformation (E120),
Fax: +43-(0)1-58801-912246              Research Group Photogrammetry
Email: lukas.winiwarter at tuwien.ac.at    Gußhausstraße 27-29
http://photo.geo.tuwien.ac.at/          1040 Vienna, Austria
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170522/5dbfb0ea/attachment.html>
