[Qgis-user] QGIS 2.18.8 - Crash dump accessing PostGIS layers via browser
McDonaldR McDonaldR at angus.gov.uk
Wed May 24 05:19:42 PDT 2017
I can confirm this using Windows 7 x64 and 2.18.8
Bug reported - https://issues.qgis.org/issues/16612  - and closed already as new fix is in place and will be coming in new build 2.18.9 shortly. Suggestion is to downgrade to 2.18.7 or use the Add PostGIS Layer button.
Ross
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of QGIS.USER
Sent: 24 May 2017 10:17
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS 2.18.8 - Crash dump accessing PostGIS layers via browser
Adding to this, I have a problem with adding a list of points (from the GeoReferencer) also crashing the program (2.18.8 on Win7-64). For the time being, I have had revert back to 2.18.7.
Regards,
Ray Carpenter,
Chapel Archaeology CIC
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Chris Buckmaster
Sent: 24 May 2017 09:30
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] QGIS 2.18.8 - Crash dump accessing PostGIS layers via browser
Hi
I am using QGIS 2.18.8 and am experiencing QGIS crashing when trying to add PostGIS layers from the browser panel. I can successfully connect and add PostGIS layers thorugh the layer menu - is there a known issue / bug with using the browser panel to add db layers?
Thanks, Chris
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170524/d06b7c59/attachment.html>
