[Qgis-user] CSV Loading broken in 2.18.8 on Ubuntu?
Ian Turton
ijturton at gmail.com
Wed May 24 05:30:17 PDT 2017
I just tried to load a CSV file with no geometry selected (attached below)
into QGIS
QGIS version
2.18.8
QGIS code revision
af8fb04 <https://github.com/qgis/QGIS/commit/af8fb04>
Compiled against Qt
4.8.6
Running against Qt
4.8.6
Compiled against GDAL/OGR
2.1.0
Running against GDAL/OGR
2.1.0
Compiled against GEOS
3.5.0-CAPI-1.9.0
Running against GEOS
3.5.0-CAPI-1.9.0 r4084
PostgreSQL Client Version
9.3.4
SpatiaLite Version
4.1.1
QWT Version
5.2.3
PROJ.4 Version
480
QScintilla2 Version
2.8.1
and got the following;
➜ ~ qgis
Warning: loading of qgis translation failed
[/usr/share/qgis/i18n//qgis_en_GB]
Warning: loading of qt translation failed
[/usr/share/qt4/translations/qt_en_GB]
Warning: QCss::Parser - Failed to load file "/style.qss"
Warning: QLayout: Attempting to add QLayout "" to QgsPanelWidgetStack
"mWidgetStack", which already has a layout
Vector Tile Reader Plugin loaded...
Creating logging config failed: (<type 'exceptions.IOError'>, IOError(2,
'No such file or directory'), <traceback object at 0x7fde48be45f0>)
Lower left (0.0000,0.0000)
Upper right (0.0000,0.0000)
Normal size mode
# EasyCustomLabeling debug trace: plugin loaded at 2017-05-24
13:26:26.856510
ERROR 1: Random access not supported for /vsizip
(qgis.bin:18086): Gtk-CRITICAL **: IA__gtk_widget_get_direction: assertion
'GTK_IS_WIDGET (widget)' failed
Fatal: ASSERT failure in QList<T>::at: "index out of range", file
/usr/include/qt4/QtCore/qlist.h, line 469
Stacktrace (piped through c++filt):
/usr/bin/qgis.bin(+0xb092)[0x7fdeebbf6092]
/usr/bin/qgis.bin(myMessageOutput(QtMsgType, char
const*)+0x3a)[0x7fdeebbf621a]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(qt_message_output(QtMsgType, char
const*)+0x21)[0x7fdee9669bb1]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x70ff9)[0x7fdee9669ff9]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(qFatal(char const*,
...)+0x94)[0x7fdee966a804]
/usr/lib/libqgis_app.so.2.18.8(QgisApp::addVectorLayer(QString const&,
QString const&, QString const&)+0x371)[0x7fdeeb1108a1]
/usr/lib/libqgis_app.so.2.18.8(+0x4ff39d)[0x7fdeeb49439d]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(QMetaObject::activate(QObject*,
QMetaObject const*, int, void**)+0x2da)[0x7fdee978a87a]
/usr/lib/qgis/plugins/libdelimitedtextprovider.so(+0x2b90c)[0x7fde5e13690c]
/usr/lib/qgis/plugins/libdelimitedtextprovider.so(+0x231bb)[0x7fde5e12e1bb]
/usr/lib/qgis/plugins/libdelimitedtextprovider.so(+0x2b9c8)[0x7fde5e1369c8]
/usr/lib/qgis/plugins/libdelimitedtextprovider.so(+0x2bb63)[0x7fde5e136b63]
QMetaObject const*, int, void**)+0x4d8)[0x7fdee978aa78]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QAbstractButton::clicked(bool)+0x32)[0x7fdee915e172]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x57ba63)[0x7fdee8ec1a63]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x57cbd3)[0x7fdee8ec2bd3]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QAbstractButton::mouseReleaseEvent(QMouseEvent*)+0x6c)[0x7fdee8ec2cbc]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QWidget::event(QEvent*)+0xaca)[0x7fdee8b5f51a]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QApplicationPrivate::notify_helper(QObject*,
QEvent*)+0x8c)[0x7fdee8b0fe2c]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QApplication::notify(QObject*,
QEvent*)+0x3ad)[0x7fdee8b165dd]
/usr/lib/libqgis_core.so.2.18.8(QgsApplication::notify(QObject*,
QEvent*)+0x5b)[0x7fdee9db7f7b]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(QCoreApplication::notifyInternal(QObject*,
QEvent*)+0x6d)[0x7fdee97764dd]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QApplicationPrivate::sendMouseEvent(QWidget*,
QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&,
bool)+0x153)[0x7fdee8b15d93]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x2449eb)[0x7fdee8b8a9eb]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QApplication::x11ProcessEvent(_XEvent*)+0x1559)[0x7fdee8b8a289]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x26bb32)[0x7fdee8bb1b32]
/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x254)[0x7fdee16d3e04]
/lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x49048)[0x7fdee16d4048]
/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c)[0x7fdee16d40ec]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)+0x71)[0x7fdee97a37a1]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x26bbe6)[0x7fdee8bb1be6]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)+0x2f)[0x7fdee97750af]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)+0x175)[0x7fdee97753a5]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QDialog::exec()+0xcc)[0x7fdee8fb706c]
/usr/lib/libqgis_app.so.2.18.8(QgisApp::addDelimitedTextLayer()+0xfb)[0x7fdeeb0e285b]
/usr/lib/libqgis_app.so.2.18.8(+0x4ff381)[0x7fdeeb494381]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QAction::triggered(bool)+0x32)[0x7fdee8b09a62]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QAction::activate(QAction::ActionEvent)+0x63)[0x7fdee8b0b433]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x57cb92)[0x7fdee8ec2b92]
/usr/lib/x86_64-linux-gnu/libQtGui.so.4(QToolButton::mouseReleaseEvent(QMouseEvent*)+0xa)[0x7fdee8f79aca]
/usr/lib/x86_64-linux-gnu/libQtCore.so.4(QCoreApplication::exec()+0x89)[0x7fdee977ab79]
/usr/bin/qgis.bin(main+0x1f73)[0x7fdeebbf2f53]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7fdee8085f45]
/usr/bin/qgis.bin(+0xac74)[0x7fdeebbf5c74]
Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170524/fb3aafca/attachment.html>
Type: text/csv
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170524/fb3aafca/attachment.csv>
