[Qgis-user] QGIS 2.18.8 - Crash dump accessing PostGIS layers via browser
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Wed May 24 05:47:17 PDT 2017
You have the same problem when accessing SQL-Server based data -
* Using the "add layer" button works.
* Using the browser to add a SQL server layer crashes QGIS. The "drill
down" through databases and schemas works, but QGIS crashes when you
try to add a layer by double clicking the layer
Hope the fix cures the SQL-Server access problem too
Regards
Bo Victor Thomsen
Den 24-05-2017 kl. 10:30 skrev Chris Buckmaster:
> Hi
> I am using QGIS 2.18.8 and am experiencing QGIS crashing when trying
> to add PostGIS layers from the browser panel. I can successfully
> connect and add PostGIS layers thorugh the layer menu – is there a
> known issue / bug with using the browser panel to add db layers?
> Thanks, Chris
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170524/1437067f/attachment.html>
