[Qgis-user] editing shapelayer doesnt work
info at architekten.coop
Sun May 28 08:55:40 PDT 2017
thank you for your answer,
i found the problem. if i make a filter for the layer, i remarked a
special syntax for the source name of the layer, in layer-properties.
source
with filter: C:\...........\383ug_pol.shp|layerid=0|subset="LAYER" = 'SM_UG'
without filter C:\...........\383ug_pol.shp
with filter > editing is inactive. is this inevitable for shape layers ?
without filter > editing is possible
redards, matthias moser
Am 26.05.2017 um 08:45 schrieb Christine:
> info-2 wrote
>> ... converted datas of format dwg ( autocad) to shape file, with program
>> cad2shape 4.0 then i builded in qgis a shapelayer an added two more
>> columns and filled up the features, all works fine. after all, i saved as
>> qgis project.
>> after closing qgis and restarting the projectfile, i could no more change
>> the editing status of the layer, to work with the features, the whole
>> digitizing toolbar was inactive.
> Have you saved your changes to your shapefile before toggling/leaving
> editing mode?
> That's not the same as to save the QGIS project file (*.qgs), see *
> <http://docs.qgis.org/2.0/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html>
> Editing* , particularly section "Digitizing an existing layer".
> Regards, Christine
> View this message in context: http://osgeo-org.1560.x6.nabble.com/editing-shapelayer-doesnt-work-tp5321894p5321899.html
> Sent from the QGIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
