[Qgis-user] Combine several attribute tables
DelazJ delazj at gmail.com
Tue May 30 07:23:21 PDT 2017
"Vector menu --> Data Management Tools --> Merge Vector Layers" should do
that. Depending on the QGIS version,  you may need to enable in Plugins
Manager either Processing or FTools beforehand.
Also, you can use virtual layers as explained at
https://gis.stackexchange.com/questions/215041/can-i-combine-two-heat-maps-in-qgis/215063#215063
(thanks Alexandre)
Hope that helps,
DelazJ
2017-05-30 15:51 GMT+02:00 Anke zur Gölden <a.goelden at googlemail.com>:
> Hello
> i have some vector layer data in different vector layer tables (same
> structure!).
> Is there a way to combine them into one single attribute table?
> example
> table 1:
> row 1
> row 2
> row 3
> table 2:
> row 4
> row 5
> row 6
> put them together in one single table:
> row 1
> row 2
> row 3
> row 4
> row 5
> row 6
> thnaks
> anke
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170530/a910e263/attachment.html>
