[Qgis-user] crash on startup
Frank Howell frankmhowell at gmail.com
Wed May 31 13:01:43 PDT 2017
I get the following messages piped back to the terminal when I execute QGIS
2.18.9 with ubuntu dependencies.  I'm using Linux Mint 2.18.1 with Cinnamon
x64 3.2.7 and kernal version 4.8.0-51 generic:
frank at lil-jonny ~ $ qgis &
[1] 43028
frank at lil-jonny ~ $ Warning: loading of qgis translation failed
[/usr/share/qgis/i18n//qgis_en_US]
Warning: loading of qt translation failed
[/usr/share/qt4/translations/qt_en_US]
Warning: QCss::Parser - Failed to load file  "/style.qss"
QInotifyFileSystemWatcherEngine::addPaths: inotify_add_watch failed: No
such file or directory
Warning: QFileSystemWatcher: failed to add paths:
/home/frank/.qgis2//project_templates
Warning: QLayout: Attempting to add QLayout "" to QgsPanelWidgetStack
"mWidgetStack", which already has a layout
QH6248 qh_lib_check: Incorrect qhull library called.  Caller uses reentrant
Qhull while library is non-reentrant
QH6249 qh_lib_check: Incorrect qhull library called.  Size of qhT for
caller is 8184, but for library is 2896.
QH6255 qh_lib_check: Cannot continue.  Library 'qhull 7.2.0 (2015.2
2016/01/18)' uses a dynamic qhT via qh_QHpointer (e.g., qhull_p.so)
The package "qhull.bin" is installed.
Any thoughts?
Frank
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170531/ae3b9a2c/attachment.html>
