[Qgis-user] Snapping: Move Features vs Node Tool
Martin Bain Martin.Bain at lismore.nsw.gov.au
Wed May 31 16:20:59 PDT 2017
Hi Randy,
I've come to accept that's just the way it is.  It would be nice if the move tool did snapping.  I guess it might be tricky to implement - with the node tool the cursor position and node being moved are one and the same, but with the move tool that’s not always the case.
As an aside are you using the wonderful CAD Node Tool plugin, https://github.com/qgis/QGIS-Enhancement-Proposals/issues/69 ?  The built node tool became quite sluggish for me after QGIS 2.8 for some reason.  The plugin is much more fluid and the best thing is it does topological editing across layers.  Its not perfect though - you can't select a sequence of nodes and move them at the same time.
Cheers,
Martin.
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Randal Hale
Sent: Tuesday, 30 May 2017 11:53 PM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Snapping: Move Features vs Node Tool
A question.
In an attempt to help a client I'm doing some data cleanup - which is good. I spend too much time talking and not enough doing. I need to snap points to the endpoints of lines. If I set snapping up and use the move features tool the point doesn't snap to the line. If I move the point using the node tool the point snaps to the line.
I've been looking for an option or something to change. I'm not seeing one. Is this expected behavior? To me it would make more sense for both tools to snap data - but I may be missing something. If I add data, the data snaps as I would expect it. The good people I'm helping immediately started moving data and it didn't snap - and I've instructed them to use the node tool to make the edits.
QGIS 2.18.9 - Linux
Thanks
Randy
Randal Hale
rjhale at northrivergeographic.com
https://www.northrivergeographic.com
(423) 653-3611
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
This email is intended for the named recipient only.  The information it contains may be confidential.  If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it.  If you have received this email in error, please contact the sender immediately and delete the message.
