[Qgis-user] Rule based style - categorize- label
Richard Duivenvoorde rdmailings at duif.net
Fri Oct 20 04:00:17 PDT 2017
On 20-10-17 12:46, DelazJ wrote:
> Hi Lene,
> May be you could file a feature request (won't help you yet :( ). Given
> that this classification is an automated process (based on equality), it
> may be possible to return a valid label that is different from the class
> rule (and i guess it'll be helpful for legend).
IF you do, maybe then make it optional, with a checkbox 'use only value
as Label' or so?
Because I think seeing the full rule can also be very informative?
Regards,
