[Qgis-user] Browser Panel Import
Steven Evans steven.evans at parkes.nsw.gov.au
Tue Sep 5 15:55:27 PDT 2017
Hi;
An issues log has been created a couple of months ago.
https://issues.qgis.org/issues/16805
I too fell for the same trap…
I'm encouraging my end users to stick to double click not drag-drop until this can be resolved…
Regards
Steve
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Alessandro Pasotti
Sent: Tuesday, 5 September 2017 7:33 PM
To: Richard Duivenvoorde
Cc: qgis-user at lists.osgeo.org; Shaun Goodenough
Subject: Re: [Qgis-user] Browser Panel Import
On Tue, Sep 5, 2017 at 9:14 AM, Richard Duivenvoorde <rdmailings at duif.net<mailto:rdmailings at duif.net>> wrote:
While it's nice to impress new users to use this 'drag a file into a
database' feature :-) .... I think it's also a 'shoot and run' solution:
either OK or nothing...
Would it be an idea to (sorry dialog haters) have a summary/confirmation
dialog in between this action? Telling the user that 'this file/table
with such columns be copied/moved to that file/table with these columns'?
In this case, it would also have made it possible to stop this overwrite
action?
I don't think it's a good design: if the result of the action is reversible a confirm dialog is unnecessary, and we are trying to elminate all unnecessary modals.
I'd stick to the confirm dialog for all potentially destructive actions.
I recommend to follow the new geopackage implementation behavior:
- if the drop is on self: abort
- if the drop overrides an existing table: confirm
- if the drop does not override and hence creates a new table: notify on success or error
If you've done a wrong drop, you can easily delete the imported layer (at least now it's implemented for geopackage and all ogr/gdal, provided it's supported by the gdal/ogr provider)
Regards.
Regards,
On 05-09-17 09<tel:05-09-17%2009>:04, Alessandro Pasotti wrote:
> It looks like a bug.
> Did you file a ticket?
> The expected behavior is that the layer you are dragging is imported
> (without overwriting!) into the destination DB (the drop target).
> In case of overwriting, a confirm dialog should appear.
> I've recently worked on that for geopackage and I've also added some
> logic to prevent dropping onto itself (that could lead to data loss).
> Cheers
> On Tue, Sep 5, 2017 at 8:39 AM, Martin Bain
> <Martin.Bain at lismore.nsw.gov.au<mailto:Martin.Bain at lismore.nsw.gov.au> <mailto:Martin.Bain at lismore.nsw.gov.au<mailto:Martin.Bain at lismore.nsw.gov.au>>>
> wrote:
>     Hi List,____
>     I just discovered a brutal feature of the Browser Panel.____
>     __ __
>     When browsing SQL Server if you happen to click and drag on a table
>     then when you release the mouse button a dialog box will pop up
>     saying “Import Competed”.____
>     __ __
>     The table under the cursor when mouse button is released gets
>     overwritten with an empty table, without any sort of prompt!____
>     __ __
>     Within SQL Server I have now revoked DDL permissions from the user
>     that did this (and myself).____
>     __ __
>     But was wondering, Is there a way to prevent or modify this
>     behaviour in QGIS?____
>     __ __
>     Thanks,____
>     Martin.____
>     This email is intended for the named recipient only. The information
>     it contains may be confidential. If you are not the intended
>     recipient you must not reproduce or distribute any part of this
>     email, disclose its contents to any other party or take any action
>     in reliance on it. If you have received this email in error, please
>     contact the sender immediately and delete the message.
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org> <mailto:Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3:   www.itopen.it<http://www.itopen.it> <http://www.itopen.it>
Alessandro Pasotti
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170905/f5bf07a0/attachment.html>
