[Qgis-user] Building QGIS >= 2.18.12 on Linux Mint 18.2 Sonya - with Oracle provider?
Matthias Kuhn matthias at opengis.ch
Tue Sep 19 05:04:52 PDT 2017
Hi Greg,
Not sure what exactly is going wrong when it freezes.
But since it happens at 99% it's possible that all the important parts
are already there and you are already able to start QGIS. Go to the
build directory and type
  ./output/bin/qgis
It's possible that this just works.
Good luck,
Matthias
On 09/19/2017 12:17 PM, Greg Stef wrote:
> Hello everyone.
> This is my 1st post and I am not sure if it should be short or more
> detailed. I have posted a question to Stackexchange
> (https://gis.stackexchange.com/questions/255565/building-qgis-2-18-12-on-linux-mint-18-2-sonya-with-oracle-provider),
> with no answers so far, so I'll provide the most essential details here,
> unless told otherwise.
> I was trying to build QGIS on Linux Mint 18.2 (Sonya), in order to have
> the Oracle provider - my setup is at the end of this message.
> I tried to follow the instructions in
> https://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc11
> , specifically 3.1 - 3.7 (3.8 seems to be a separate process, which I
> also tried and failed) - in 3.3 I used the build dependencies for xenial.
> Since this official guide doesn't mention Oracle at all (as if nobody
> uses it!),  I searched and tried to use a process like
> https://lists.osgeo.org/pipermail/qgis-developer/2014-August/034230.html. My
> command was:
> |ccmake -DWITH_QWTPOLAR=OFF -DCMAKE_BUILD_TYPE=Debug
> -DCMAKE_INSTALL_PREFIX=/home/ME/apps/qgis/master -DWITH_ORACLE=TRUE
> -DOCI_INCLUDE_DIR=/home/ME/instantclient_12_2/sdk/include
> -DOCI_LIBRARY=/home/ME/instantclient_12_2/libclntsh.so.12.1 ..
> |make -j|8
> It failed (my 1st attempt in compiling, too).
> Before going around asking questions, I thought it prudent to assure the
> basics, so I tried to build the 'vanilla way', i.e. from the source as I
> download it, without Oracle, without any changes in the process. I made
> LD_LIBRARY_PATH null and issued:
> -DCMAKE_INSTALL_PREFIX=/home/ME/apps/qgis/master ..|
> |make -j|8
> After about 15',  I got:
>     [ 99%] Building CXX object
> src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qtermwidget/moc_kptyprocess.cpp.o
> src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qtermwidget/moc_qtermwidget.cpp.o
> src/plugins/grass/7/CMakeFiles/grassplugin7.dir/qrc_qgsgrass_plugin.cpp.o
>     Scanning dependencies of target translations
>     [ 99%] Generating ../output/i18n/qgis_ar.qm
>     [ 99%] Generating ../output/i18n/qgis_bg.qm
>     [ 99%] Generating ../output/i18n/qgis_bs.qm
>     [ 99%] Generating ../output/i18n/qgis_ca.qm
>     [ 99%] Generating ../output/i18n/qgis_cs.qm
>     [ 99%] Generating ../output/i18n/qgis_da.qm
>     [ 99%] Generating ../output/i18n/qgis_de.qm
>     [ 99%] Linking CXX shared module
> ../../../../output/lib/qgis/plugins/libgrassplugin7.so
>     [ 99%] Built target grassplugin7
>     [ 99%] Generating ../output/i18n/qgis_el.qm
> where it remained frozen, with 100% cpu, for > 20h.
> Next day, whet I interrupted the process, I got
> i18n/CMakeFiles/translations.dir/build.make:97: recipe for target
> 'output/i18n/qgis_ar.qm' failed
> make[2]: *** [output/i18n/qgis_ar.qm] Interrupt
> i18n/CMakeFiles/translations.dir/build.make:105: recipe for target
> 'output/i18n/qgis_bs.qm' failed
> make[2]: *** [output/i18n/qgis_bs.qm] Interrupt
> i18n/CMakeFiles/translations.dir/build.make:109: recipe for target
> 'output/i18n/qgis_ca.qm' failed
> make[2]: *** [output/i18n/qgis_ca.qm] Interrupt
> i18n/CMakeFiles/translations.dir/build.make:117: recipe for target
> 'output/i18n/qgis_da.qm' failed
> make[2]: *** [output/i18n/qgis_da.qm] Interrupt
> i18n/CMakeFiles/translations.dir/build.make:121: recipe for target
> 'output/i18n/qgis_de.qm' failed
> make[2]: *** [output/i18n/qgis_de.qm] Interrupt
> i18n/CMakeFiles/translations.dir/build.make:125: recipe for target
> 'output/i18n/qgis_el.qm' failed
> make[2]: *** [output/i18n/qgis_el.qm] Interrupt
> i18n/CMakeFiles/translations.dir/build.make:113: recipe for target
> 'output/i18n/qgis_cs.qm' failed
> make[2]: *** [output/i18n/qgis_cs.qm] Interrupt
> i18n/CMakeFiles/translations.dir/build.make:101: recipe for target
> 'output/i18n/qgis_bg.qm' failed
> make[2]: *** [output/i18n/qgis_bg.qm] Interrupt
> CMakeFiles/Makefile2:4155: recipe for target
> 'i18n/CMakeFiles/translations.dir/all' failed
> make[1]: *** [i18n/CMakeFiles/translations.dir/all] Interrupt
> Makefile:160: recipe for target 'all' failed
> make: *** [all] Interrupt
> I find it *very* frustrating (to put it mildly) that a gis user who
> chose Linux as his OS,  must go through all these hoops to get Oracle
> support - or switch to Windoze.
> My last hope is to all you out there.
> Thanks in advance
> Greg
> My setup:
> |uname -a Linux GIS81 4.10.0-33-generic #37~16.04.1-Ubuntu SMP Fri Aug 11
> 14:07:24 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux lsb_release -a No LSB
> modules are available. Distributor ID: LinuxMint Description: Linux Mint
> 18.2 Sonya Release: 18.2 Codename: sonya|
> |echo $LD_LIBRARY_PATH
> /home/<ME>/instantclient_12_2:/home/<ME>/instantclient_12_2/libclntsh.so.12.1:
> echo $PATH
> /home/<ME>/instantclient_12_2:/home/<ME>/bin:/home/<ME>/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
> |locale LANG=en_GB.UTF-8 LANGUAGE=en_GB LC_CTYPE="en_GB.UTF-8"
> LC_NUMERIC=el_GR.UTF-8 LC_TIME=en_GB.UTF-8 LC_COLLATE="en_GB.UTF-8"
> LC_MONETARY=el_GR.UTF-8 LC_MESSAGES="en_GB.UTF-8" LC_PAPER=el_GR.UTF-8
> LC_NAME=el_GR.UTF-8 LC_ADDRESS=el_GR.UTF-8 LC_TELEPHONE=el_GR.UTF-8
> LC_MEASUREMENT=el_GR.UTF-8 LC_IDENTIFICATION=el_GR.UTF-8 LC_ALL= |
> Qgis-user mailing list
