[Qgis-user] Building QGIS3 for OS X with MacPorts
Patrick Dunford blackwhitekez at gmail.com
Wed Sep 20 22:24:58 PDT 2017
Ok so I gave you a Linux answer :)
The install file I have says you do a postgresql installation through
this site, I assume that is supposed to provide the libraries you need
www.kyngchaos.com/software/postgres
I would guess from that you should be able to work out if it has
provided the library file as part of that.
On 21/09/17 13:58, David Liontooth wrote:
> Great, thanks!
> Does QGIS3 require postgresql?
> I didn't think it did, but the build bugs out:
>    In file included from
> /Users/liontooth/software/QGIS/QGIS-2.99a/tests/src/providers/testqgspostgresprovider.cpp:4:
> /Users/liontooth/software/QGIS/QGIS-2.99a/src/providers/postgres/qgspostgresprovider.h:24:
> /Users/liontooth/software/QGIS/QGIS-2.99a/src/providers/postgres/qgspostgresconn.h:33:10:
>    fatal error: 'libpq-fe.h' file not found
>    #include <libpq-fe.h>
>    1 error generated.
> /tests/src/providers/testqgspostgresprovider.cpp seems to demand it.
> Cheers,
> Dave
> On 9/20/17 11:01 AM, Patrick Dunford wrote:
>> 3.0 is not released yet, you can only get 2.99 development versions.
>> You get them from Github:
>> https://github.com/qgis/QGIS
>> Click on "Clone or Download" button on the right and then "Download Zip"
>> This is for the latest release, you can get older ones if you know
>> the commit ID
>> On 21/09/17 05:51, David Liontooth wrote:
>>> I followed David Marteau's very helpful instructions for building
>>> QGIS3 at
>>> https://www.3liz.com/blog/rldhont/index.php?post/2017/06/01/How-to-build-qgis-on-OSX-with-MacPort,
>>> on a Sierra OS X with all updates and a current MacPorts installation.
>>> I needed to add these dependencies:
>>>     lbzip2 py36-setuptools
>>> Where can I find QGIS 3.0 source files? I downloaded
>>> http://qgis.org/downloads/qgis-latest.tar.bz2, but that's qgis-2.18.13.
>>> I also tried https://github.com/wonder-sk/QGIS/archive/3d-2.zip,
>>> using Marteau's makefile, replacing spaces with tabs. Cmake didn't
>>> find libzip, so I modified
>>>     cmake/FindLibZip.cmake txt2tags
>>> to include the paths to MacPort's libzip package (/opt/local/..).
>>> However, there's a syntax error relating to the 3D features,
>>> reported separately.
>>> Is there a mainline version of QGIS3 we can test build, just to get
>>> ready for the release?
>>> Cheers,
>>> Dave
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
