[Qgis-user] [QGIS-Developer] QGIS 3 Print Composer - Page Properties
Nyall Dawson nyall.dawson at gmail.com
Mon Apr 2 21:16:06 PDT 2018
On 3 April 2018 at 07:06, Carlo A. Bertelli (Charta s.r.l.)
<carlo.bertelli at gmail.com> wrote:
> I suggest to provide the same interface as version 2 calling this "default
> page size" and explaining that every page could get a different size,
> right-clicking on the page. Most users make one-page maps and they would
> never need this otherwise vital feature.
I've thought long on this. I'm reasonably convinced it's a short-term
issue as people adjust there 2.x workflows to 3.0.
There's two approaches I can see working to mitigate it:
1. Add a "pages panel", which allows you to pick from existing pages
(e.g. via a drop-down combo box) and then set the properties for that
page. It could also have the actions for adding new pages and deleting
existing pages there too.
and/or
2. Add a "new layout wizard", which shows when you create a new print
layout. This would prompt users to set the page size before the layout
is actually created. It could potentially replace the existing layout
manager approach to creating layouts from a template, e.g. by showing
a nice list of available templates via thumbnail graphics.
Unfortunately both approaches aren't trivial, and would require some
hours to implement.
Nyall
> c
> On Mon, Apr 2, 2018 at 10:01 PM, Alessandro Pasotti <apasotti at gmail.com>
> wrote:
>> The reason for this change is that your can now have different settings
>> for each page.
>> The page size is not a property of the layout anymore but it's a property
>> of the page.
>> But I agree that the page properties might be better exposed.
>> On Mon, Apr 2, 2018, 21:56 C Hamilton <adenaculture at gmail.com> wrote:
>>> I was just going to ask what happened to the "Page Size" properties in
>>> the QGIS 3 print composer, but I stumbled upon it accidentally by
>>> right-mouse clicking on the page and selecting "Page Properties." This was
>>> not easily found. In the QGIS 2 print compose it is a part of the layout. In
>>> QGIS 3 I just lucked out.
>>> Could the page properties be more obvious to find? At lease add them to
>>> the Layout or Edit menus or put them back under the layout settings.
>>> Thanks,
>>> Calvin
> Carlo A. Bertelli
>    Charta servizi e sistemi per il territorio e la storia ambientale srl
>           Dipendenze del palazzo Doria,
>           vc. alla Chiesa della Maddalena 9/2 16124      Genova (Italy)
>           tel./fax +39(0)10 2475439  +39 0108566195  mobile:+39 393 1590711
>    e-mail: bertelli at chartasrl.eu      http://www.chartasrl.eu
> Qgis-user mailing list
