[Qgis-user] True North
Andreas Neumann
a.neumann at carto.net
Wed Apr 4 04:56:00 PDT 2018
Hi Daniel,
Just do not reply to this e-mail thread, but send a plain new e-mail to
"qgis at user@lists.osgeo.org" describing your problem with enough detail
that others can follow.
Note also that this is an english language e-mail list - there may be
some spanish speaking subscribers on the list, but you are more likely
to get replies if you write in english. Or - alternatively - if you want
to write in spanish - you may use a localized e-mail list in a different
language. See https://wiki.osgeo.org/wiki/Local_Chapters or
https://www.qgis.org/en/site/forusers/usergroups.html as a starter.
Going back to your "Update column" question - please have a look a the
"Field Calculator" - see the corresponding section in the QGIS manual:
https://docs.qgis.org/2.18/en/docs/user_manual/working_with_vector/field_calculator.html
Greetings,
Andreas
On 2018-04-04 13:45, Daniel Alejandro Montecinos Rubilar wrote:
> Ok, entonces podría indicarme en que correo solucionan ese problema, por favor? Necesito hacer ese cruce con urgencia y no encuentro la solucion.
> Desde ya muchas gracias
> DE: Qgis-user <qgis-user-bounces at lists.osgeo.org> en nombre de Andreas Neumann <a.neumann at carto.net>
> FECHA: miércoles, 4 de abril de 2018, 08:41
> PARA: <qgis-user at lists.osgeo.org>
> ASUNTO: Re: [Qgis-user] True North
> Dear Daniel,
> Harrison just meant that is not nice to "hijack" an existing topic thread. If you have a different issue, you should start a new e-mail thread just for that new issue.
> Andreas
> On 04.04.2018 13:38, Daniel Alejandro Montecinos Rubilar wrote:
> Dear, what you refered? The question is not understood or there is no solution?
> DE: Springfield Harrison <stellargps at gmail.com>
> ORGANIZACIÓN: Stellar GPS & Mapping
> FECHA: martes, 3 de abril de 2018, 17:53
> PARA: Daniel Alejandro Montecinos Rubilar <daniel.montecinos.r at gmail.com>
> CC: <qgis-user at lists.osgeo.org>
> Hello Daniel,
> You are on quite a different topic here.
> I think you should repost your inquiry using a different subject...
> Cheers . . . . . Springfield Harrison
> On 03-Apr-2018 06:35, Daniel Alejandro Montecinos Rubilar wrote:
> GOOD MORNING,
> I have a query, I have use Mapinfo for several years and I was discover QGIS program and I want change me, but I'am searching one similar function but I dont found. This function, in Mapinfo, his name is "Update Column". Below I leave an image
> I appreciate your help, it is urgent!!!
> [2]
> Virus-free. www.avg.com [2]
> Qgis-user mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
_______________________________________________ Qgis-user mailing list
Qgis-user at lists.osgeo.org List info:
https://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe:
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-user
[2]
http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180404/924cd0c1/attachment.html>
