[Qgis-user] Principal Components Analysis Problem
Nyall Dawson nyall.dawson at gmail.com
Thu Apr 12 17:05:46 PDT 2018
On 11 April 2018 at 16:57, Grant Boxer <boxerg at iinet.net.au> wrote:
> I am trying to do a PCA on ASTER satellite data using bands 4 through 9 (all
> 30 m pixel size). I have tried using the Processing Toolbox > Grass >
> Imagery>i.pca but it continually fails.
> I get this at the end of processing.
> _____________________________________________________________________________________________________________
> Traceback (most recent call last):
> File
> "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\algs\grass7\Grass7Algorithm.py",
> line 395, in processAlgorithm
> if isinstance(out, QgsProcessingOutputHtml):
> NameError: name 'QgsProcessingOutputHtml' is not defined
Unfortunately this is a known bug in 3.0.1, fixed in the upcoming
3.0.2 version (along with a TON of other Processing GRASS plugin
fixes).
As a short-term fix you could try downloading the qgis-rel-dev package
via osgeo4w64 to get access to these fixes before the official release
of 3.0.2.
Nyall
> Execution failed after 16.32 seconds
> Loading resulting layers
> Algorithm 'i.pca - Principal components analysis (PCA) for image
> processing.' finished
> When using the SemiAutomatic Classification PCA calculator I get the
> following error message.
> 2018-04-11T14:51:00 WARNING Traceback (most recent call last):
> File
> "C:/Users/Grant/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\SemiAutomaticClassificationPlugin\maininterface\pcaTab.py",
> line 46, in calculatePCAAction
> self.calculatePCA()
> File
> line 97, in calculatePCA
> self.PCACalculation(rD, bL, outF, numbComp, None, batch)
> File
> line 140, in PCACalculation
> comp, totalVariance, totalVarianceCumulative, eigenValues =
> self.calculateEigenVectors(covM)
> File
> line 264, in calculateEigenVectors
> val, vect = cfg.np.linalg.eigh(matrix)
> File
> "C:\PROGRA~1\QGIS3~1.0\apps\Python36\lib\site-packages\numpy\linalg\linalg.py",
> line 1291, in eigh
> w, vt = gufunc(a, signature=signature, extobj=extobj)
> File
> line 96, in _raise_linalgerror_eigenvalues_nonconvergence
> raise LinAlgError("Eigenvalues did not converge")
> numpy.linalg.linalg.LinAlgError: Eigenvalues did not converge
> Can anyone shed any light on what is happening here?
> Cheers Grant
> Grant Boxer (FAIG RPGeo)
> Maylands, Western Australia, 6931
> Qgis-user mailing list
